I finally got around to putting in my Banks Pedal Monster and Idash combination and a mounting hickey that I purchased from our forum group buy a few months back. It was a little more of an installation than just plug and play, but it wasn’t overly difficult. The directions that come with the Idash are pretty decent and lay out the process step by step. The most difficult thing for me to figure out was how to remove a few of the parts in my truck dash in order to get the wires for the Idash where I wanted them.
The first step was to remove the grab handle piece.
On this step you need to pop the two covers off on both sides of the handle. That will expose two bolts. They are 10mm heads. Take out the bolts and then pull up and out to pop the whole piece off. If you have a Lariat or above, you will also need to unplug the little speaker before you can completely remove the piece.
The next step it’s to pop off the side panel on the dash.
This part probably took me the longest time because I didn’t know how to remove it, and I really didn’t want to break anything. Well, I finally grew a set and started peeling the panel away starting at the bottom and away from the firewall. It is surrounded by quick clips, but if you’re careful, you can peel the panel towards the open drivers door. The leading edge of it tucks up behind the rubber strip on the door jamb. I didn’t need to pull it out of there, I just held it out of the way.
At this point the wires can be run up and around things and then the pieces can be put back in reverse order. Keep following the general directions from Banks and you will be good to go from there.
View attachment 29106View attachment 29107
From there it was setup and testing. The nice thing about this combination is the ability to see tons of engine, transmission, exhaust data, as well as the ability to adjust pedal performance with the touch of an up or down arrow. It also keeps the settings all of the time with no glitches and no need for a separate app to make adjustments. So far I’m very pleased. I wrote up a better review here.
I thought since we had so many people interested in the Banks Pedal Monster, it would be great to have one master thread with reviews, questions, and comments.
www.fordtremor.com
All that was left at this point was to wrap up the extra wires and to make things tidy. The Idash bundle coiled and hung nicely off of another bundle near the parking brake. I ended up putting my Pedal Monster up on the kick plate behind the console and dash. It fit nicely and is out of the way.
View attachment 29110View attachment 29111
Let me know if you have any other questions. ???
