S&B 60 gal tank
I don’t think there are any issues with the 22 and older trucks when upgrading to a larger fuel tank. The tank size limit and the DTE inaccuracy are all related to 23+ models due to the programming changes and the inability to set the computer to calculate off of 60 gallons.
I have a ‘24 and set mine to 48 gallons. It’s nice to see the extended range despite it not being completely accurate. I can live with it. Having the extended range far outweighs the inaccurate reading.
2022 F-350 S&B 60 Gallon tank install observations:
- Less than 5 hour job in the driveway by myself with breaks. Watching a couple youtubes and the S&B instructions before hand helps.
- I ran the OEM tank down a little too low at 10 miles DTE. Thought it would still have 4 gallons, but only 2.5 gallons remained--I don't recommend going below 5 gallons or more. I was carrying a 5 gal jug jof fuel just in case...
- The front driver-side tank bracket nut-clip broke in the frame, so the bolt just spun. I was able to get a 15mm open end wrench on the nut through the frame member, but it took a few minutes on that one bolt. Ford used a lot of threadlocker on the tank bracket bolts. Don't push up on those bolts when unscrewing...
- Camstrap tie downs worked great for lowering and lifting the tanks.
- The 34 gal tank came out easily once I was able to lossen the hose clamps on the filler and vent pipes with my smallest ratchet driver. Removing the 3 8mm bolts at the fuel filler opening (behind the plastic cover panel which pops right out) allowed enough play on the filler hose to get to the hose clamps.
- Had to jack up the rear of the truck to gain enough space to slide the 60 gallon tank into position.
- The S&B instructions were adequate. Not directed, but I cycled key on/off for 20 seconds several times to prime the fuel lines prior to starting. Same as for fuel filter change.
- The new tank only took 58 gallons, so I used FORScan plain english to set the tank size to 58 gallons. Over 800 miles DTE with a full tank. Now reading 715 miles DTE and the guage has moved just slightly down from full, so the new tank calculations seem to be working, but need another 100 miles to be sure.
- Very satisfied with the tank so far. Looking forward to the greater range when hauling the 5er.
A agree with @AZRocks. Easy to install. My DTE now is over 1100 miles with a full tank! 🏆🏆
I almost always get 1057 to empty when full. I will say the 60 gallon tank is the best mod I’ve done. My only gripe is that I cannot use one of those rapid fill pumps. That check valve keeps the pump from pumping full bore. I really wish they would have a work around for that before they sold the tank.
What's your DTE with an empty tank!?
I've still got ~50 gallons to empty, so I won't know until then if the system calculates correctly. My MPG is at 12.7 right now with the short city runs of late, which is likely what the DTE is based on. 19+ MPG is normal for highway driving.
I installed my 60 gallon yesterday. Of all the potential problems I could have had, the filler neck hose clamp gave me the greatest amount of grief. I ended up removing the filler nozzle screws (inside the fill door) and lowered the tank enough to reach the other hose clamp on the tank itself. It took way way way too long messing around with this one clamp. Other than that it was pretty easy. I used a cycle jack to lower the old tank and lift up the new one. Having a college aged son to help is a bonus too.
Nice, Congrats.
Yes the filler neck clamp is a pain in the ass!! I had the same problem & did the same as you.
Now, go fill it up, don’t look at the dollar amount, but rather enjoy the 1,000+ mile range. 🍻🎉
There is no other topic as frustrating with 60 gallon tank owners as the DTE reprogramming issue. I check this thread regularly in the hope that there is a solution to this dreaded infamnia. Is there a resolution or am I going to have to drive to FoMoCo and straighten this shit out?
I may have missed it, what's the problem you're having?
I just want to be able to set the DTE based upon the size of my 60 gallon tank. Unless something has changed, the maximum loadable tank size is 48 gallons.
This is a classic example of how Ford Execs end up being held hostage by some guy in his underwear.
I mean it sucks but Ford has a programming option for their tanks lol. What happens if you just reset you. You do show a certain level of fuel still correct? What happens if you reset your DTE in the cluster? Just crazy to think that it shows 0mi DTE with a half tank
23+ only
Unfortunately, the short answer to your question is yes, going to have to go to dealership. @Lunch Box 🥩🍔 is 100% right this is a 23+ issue. Talking with S&B, support and their website, https://sbfilters.com/products/68-gal-tank-powerstroke, 2023+ Models are not currently supported by EZ Lynk. It seems the 23+ models have are "locked out
My local dealership Corwin Nampa ID set my DTE to be full 60 gallon along with fuel quantity to be 60 gallon, it was pricey ~$400 yet satisfied my OCD to have some gauge accuracy.
I've verified this over the last 25,000 trips to Sturgis SD,Waco TX, Costa Mesa CA, Cle Elum WA and Kennewick WA, both have been accurate within 5% am running stock wheels/tire combination and stock suspension.
Although refueling can be a wallet emptying experience, that's offset by doing 900 mile runs w/o have to fill up, or if your towing not having to refuel every ~250 miles 🥳
This issue is definitely an annoyance, but far from the worst as far as the instruments go. I just double the DTE display and I'm close enough. The gauge itself is close enough. It takes a while before it moves at the top and leaves about 6-7 gallons at the bottom. I almost never go below 1/4 tank and usually fill up at 1/2 unless traveling. Yes, I wish it could be changed as the earlier models (Arod claims that he has done it on 23+) but the battery voltage and coolant temperature piss me off more. There is no excuse for how bad they are.
See you in Sturgis
