Red Zeppelin Build
Just an update on unplugging the overhead console's intrusion sensor module.
It's working great! It will throw a DTC in Forscan but it's not one that will cause the lamp in the cluster to illuminate in addition to no message warnings popping up in the cluster.
Not too concerned about it at all. Can plug it back in when/if I ever sell the vehicle.
They make a version of the ones @Tx-Tremor6.7 has (I believe BroncoHooves has the same ones), but with red letters. They probably won't match the Rapid Red, but they do give an idea on how the they would look with red letters - great!
This seller needs some slightly better pictures. Just saying...
Link for the badges with red!
And the post I got the link from:
My "Hack" factor is getting worse but here you go:
I must have missed this, but why are you unplugging the intrusion sensor module?
For anyone curious, here is my payload door sticker:
F350 6.7L Lariat Ultimate with Black package, no sunroof.
That is only 500 lbs more than my F250 Diesel, Lariat Ultimate, Lariat Black, no moonroof.
Interesting... my F250 Gas Tremor Lariat Ultimate, no moonroof, no Black pkg (but bedliner, LEDs, rear splash guards) is 2720lbs. I do have dual alts/batteries so that would add some weight...
Yes, I would have thought the Gas engine would be higher considering the lower weight of the engine itself. Mine is 2825 lbs.
Yeah I'm pushing similar payload as yours, only 5-600lb less than diesel f350... Not bad
I’m getting ready for my first oil change and was wondering if rotella is stuff the oil to use. I guess so
It sure is :) You can use 10W-30 if you're mostly on the highway.
@Bluezilla I know you said you wanted my fender vents, but I have an F350. Isn't yours F250? Or are you going to 'up-badge' yours? :D
Sounds like a good idea. Maybe I could find some 6.7 badges for mine as well. 🤣
Anyone have a platinum or limited tailgate?
