Red Zeppelin Build
Just ordered the SPE Gen 2 water separator drain valve :D
I'm thinking about dropping the spare tire and removing the rear tailpipe assembly to do the exhaust tip painting while it's off of the truck, instead of masking off areas of the truck.
I'm thinking about dropping the spare tire and removing the rear tailpipe assembly to do the exhaust tip painting while it's off of the truck, instead of taping off the sides of the truck.
What kind of paint are you going with? Hi temp and what brand?
My driver's door also seems to have an extra screw or rivet rolling around in it, but the magnet trick isn't working, since it sounds like it's higher up in the door. Will inspect more once I tackle the front door Jimmi jammers.
Front passenger Jimmi jammer is installed.
Build thread is postponed until I figure out how the dealership or Ford is going to fix the deep scratch on my truck.
Have any idea where the broken rivets came from? Hopefully another rivet was put in place vs something left half-ass mounted to only come apart later…
Have any idea where the broken rivets came from? Hopefully another rivet was put in place vs something left half-ass mounted to only come apart later?
Nope. It was unpainted, and I wondered the same thing as you. There's not much room to look around in there. πŸ€·β€β™‚οΈ
Afraid you’d say that - at least you’ve got proof if an issue comes up later.
If it turns out to be another rivet in the driver door I'll try to look around in there.
My coin holder tray in the console kept sliding around and doesn't have enough 'grip' like my old truck, so I added two of these binder clips with the handles removed (one at front and one at rear of console). I like to keep the coin holder tray pushed all the way to the right of me.
@Nick@ApolloOptics Can you hook me up with one of these passenger handles painted in Rapid Red (paint code D4) ? I'm doing the Jimmi jammer install soon for my truck. :) Thank you
Unfortunately, we don't have access to OEM parts, only aftermarket. That said, we can help you with the Jimmi Jammers if you need them. @fordguy74656 - Can you get the OEM parts for @BroncoHooves?
Also, regarding the door handle, you'll be better off buying the prepped door handle and having your installation shop paint it to match your truck. They can pull your fuel door off and use that to blend the color correctly to match.
On metallic colors, especially Star White and Rapid Red, you always want to blend to the fuel door to match.
For example, when we were getting the chrome paint-matched on my 2019 Super Duty, there were 11 different shades of Ford's "White Platinum Tri-Coat" and we used the fuel door to match. Came out perfect.
SPE drain valve installed! Really was surprised of the amount of fuel and how long it took for the separator to drain completely.
Side note: totally awesome that a 5 gallon bucket can fit under this truck with zero issues. Not many trucks can say the same πŸ˜‚
Picked up an oil filter with my Ford pass points.
Also ordered a passenger side handle for the driver's side Jimmi jammer install. Also used my Ford pass points for this.
Will try to get it painted within the next few weeks.
My SPE drain valve appears to be slowly weeping/leaking.
That's a feature. The slow weeping will slowly ensure any water collected in the separator leaves without you needing to check it. :P
