Red Zeppelin Build
Threw one of these kits in the truck today. Was tired of the cheap plastic-handled kits always breaking whenever I needed it most, generally helping someone else. These are solid metal turned on a lathe.
https://www.amazon.com/dp/B000NZSZPO
Those look really nice! I have the Boulder Tools repair kit in my truck, which has metal handles and looks very similar but is cast... I have yet to use it so I can't comment on durability.
Update: got to use this kit for the first time today. Noticed a psi drop in my passenger rear tire, and sure enough found a screw in it. Got it resolved quickly and with no fighting the tools, unlike the cheap kits that have plastic handles. Having on-board air sure is a nice luxury too.
man sorry you had to do a repair but that kit does look legit. I have had to do this several times roadside but this kit looks like a game changer!
Why are your wheel studs so long? They also look like there is no nut on them.
What am I missing from your picture?
Old posts located here for context:
I remember reading that thread when you put the studs on with the stock wheels, and I was thinking about doing it bc it looked really good. But then I saw how much those NASCAR studs cost, and I was down for the count on that one 😂
Update 2: kit is paying off already. Plugged the same freakin tire today for another screw I picked up somewhere!
Hows that inverter working in your vehicle? Ever find yourself needing the plugs in the vehicle? I am considering something simpler in a box in the bed, but not sure if I would regret not wiring it into the cab.
I've been enjoying a new direction of the build process lately. Got a headache rack and bed rails installed for future lumber, kayak, and RTT needs! Thank you @Vecman for the bed rails!
Upcoming/future plans: Leitner ACS roof rack, Starlink and Weboost.
Today I installed the following:
  • Midland MXAT03 3dB antenna
  • Charvonia Design load stops/tie downs for headache rack
  • Custom Solutions PNW high mount cargo camera relocate for headache rack
So tell me about this camera or send me to a link. I need one for the front bumper.
Enjoy it and use it all the time! Even the plugs in the cab.
Haven't updated thread in awhile.
Things planned/wanted for either later this year or early next year. All depends on BFGoodrich's launch timing for unreleased tires (slated for this year according to them). I still need to burn another 25K miles on the Mickey Thompson Baja Boss A/Ts, currently halfway to the 50K treadwear warranty. I put almost 25K miles on the truck in less than a year!
Wanted Wheels: Innov8 18x9" G700, non-beadlock, in satin black. Might ask if they can do custom powder work for a two tone powder coat (black/rapid red). Leaning towards a +12 offset currently on the G700 so I can maintain a flush tread to fender flare look.
Wanted Tires: 40x13.50R18 BFGoodrich KO3.
Truck as it stands today:
Stuff wanted:
Are you purposely omitting talking about suspension upgrades you’re going to make to clear those 40s?
Yes sir. It's up in the air whether I want to do E-venture or not, or something else.
Finished up the pure sine wave inverter install today!
How did you connect your dash and bed outlets to this? does one GFCI outlet go to the two inside outlets and the other to the bed?
I usewde my Samlex inverter today for about 6 hours to power music for an endurance run aid station, didn't even move the needle for the batteries. They re-charged in about 30 minutes. Samlex is very efficient and runs cool. Very happy with this choicde. Also was a choice based on @BroncOh install.
Mine is installed in the bed to run stuff back there. This was today at the races.
