Red Zeppelin Build
While no scientific numbers like I would normally like to have, I can tell right away bumps/joints/speed bumps are much more comfortable with the Tremor stock leaf springs
That is the kind of harmless /non geometry changing/ cost effective suspension improvement i might consider doing too, along with bilstein steering stabilizer and maybe their 5100 series shocks down the road if and when oem ones start to act up. Right now the 23 oem setup is as smooth as butter (knock on wood) no reason to disturb what ain't broken.
Ordered a set of the Carli shackles, after reading the instructions decided the return on investment was not worth the effort needed to do the install. Returned them!
Joining the aftermarket bumper club soon.
Took advantage of black friday and ordered a Steelcraft HD bumper and Yankum Groove Hawse.
Warn 16.5ti-s winch will be a future purchase and install.
It is going to look awesome, can't wait to see it in place!
Nice! I like that Yankum groove thing too and dispensing with the heavy projectile on the end of the line.
I may relocate/add the black front Ford emblem to the center of the bumper with a SLS printed Nylon fairing/adapter. Still on the idea drawing table. This will yield an OEM look, better camera visibility, in addition to allowing for a longer light bar to mount directly below the emblem.
Did a mod I forgot to do after I deleted the pull rods for all the doors. Took @Lunch Box 's idea and put a Hooves twist on it. I used a Christmas tree push pin from the Harbor Freight push pin assortment, in addition to a 3D printed TPU grommet while removing the original OEM bezel portion on the door. Low profile and fits snugly.
This prevents passengers from putting trash in doors, such as drinking straw wrappers, etc. Just wanted to be proactive. Also looks better of course.
Attaching the STL print files here at the bottom of this post (remove .txt from the end of filename). One is for the front doors, the other for the rears. The rear door skins had a different ID is why.
That's a good looking bumper.
Excited to get it and see how the existing camera view is affected; if itโ€™s good, I can always add another Ford emblem to the front, just the one without the camera option.
Here is the remaining list of damage protection items I want to add to my build:
  • Talonโ€™s Garage DPF and transmission skid plates
  • Carli front diff guard
  • CJC rear bumper, or pipe style rear bumper
  • Magnum Low Profile Headache Rack (with camera relocate) โ€“ sku: 221L
  • Magnum Bed Rails โ€“ sku: RK28176
Bumper arrived today. Just waiting on winch next and a fairlead mount flip up license bracket.
Won't really exactly know the camera view until it's installed, but hoping the bumper won't have to come off again if I decide to put a Ford emblem with camera on the front.
If I can find where the other end of the camera wire ties into the main harness under the hood, I could negate the need to pull the bumper and grill off and just abandon the existing camera wire and washer hose.
Bumper arrived today. Just waiting on 16.5ti-S winch next and a fairlead mount flip up license bracket.
That thing is all business...
I installed a ranch hand legend bumper once similar to that. I used about 4 people, in hindsight an engine lift would work great if you have access to one. Nice bumper!
I really dig the look, especially if you can pull off the ford badge idea.
Saw a similar but slightly different one today on a 23, not sure if by the same company or not.
Sherpa 17.5K winch box arrived damaged and I saw part of the yellow winch body sticking out, so I'm not sure I can trust it. Emailed Sherpa wondering why they didn't bother to package it within another box. Obviously they don't understand that rule #1 when shipping is to not mark a package as fragile.
Disappointing as now I can't mount the bumper until they come through.
Got permission to open the box from them. Disappointed is an understatement.
Ooof. I was hoping it was just box damage, but thatโ€™s not good at all. :(
Hope they handle it properly with a prompt replacement, and properly packaged this time.
They claim the grease is from the summer heat in Australia causing it to leak out of the gearbox (winch is made in and shipped from Australia).
My thoughts are: if the unit is advertised at keeping water out, that should mean keeping grease in..
