- OP 🔹
- #881
If the shackles are straight like stockers and the same length, you'll accomplish nothing aside from having a zero fittingI assume you are just installing the Carli shackles, on your stock leaf springs? Please elaborate what this will accomplish. I find this interesting and something I may want to do. Price on the set of Carlie shackles.
Not correct, bushings are totally different. Read the description. Allow for free articulation.If the shackles are straight like stockers and the same length, you'll accomplish nothing aside from having a zero fitting
Mostly stock truck or full Carli setup? I have a set that are waiting on me to install.These shackles do nothing except look pretty.
Signed:
Proud owner of truck with these pretty shackles on it.
@oops has the full e-venture setup.Mostly stock truck or full Carli setup? I have a set that are waiting on me to install.
Starting to lean towards a 17” wheel with a 35” tire to help my ride.
I have a set ordered, but I'm all about looking pretty,!!@oops has the full e-venture setup.
I am curious if these really will not help. I have been wanting to install these or Sulastics for a better ride in the rear on my stock suspension ride.
I think only you can decide that based on your opinion of the stance and ride quality. If I was unhappy with either (I'm not, btw) I would want to ride in someone's truck as close to what I think I wanted first.
I know Tejas is a big state, but maybe @Tx-Tremor6.7 is close by... I think he has a Carli lift with Deavers and 37s. Ride is such a subjective thing that I wouldn't want to blow a bunch ofonly to find out it didn't do what I was hoping...
When they finally wear out, I am planning to replace them with the same size Toyo AT3s for a smoother ride.
Interested to see how this turns out for you on the stock leaves... I wouldnt expect much since you will still have the vulcanized rubber bushings on your leaf spring eyes (unless you find a way to punch them out and replace with a greaseable urethan bushing).That's correct. Wanted something not goofy like the Sulastic shackles with their multi-washer stackup/shims. Wanting to see how much jar is reduced compared to the OEM shackles. Incremental upgrade stuff to see which yields the best bang for buck.
$265 https://www.cjcoffroad.com/products...af-spring-shackle?_pos=1&_sid=5974fd7d7&_ss=r
If you have the equipment to test please do! I would love to see any scientific data over the seat of the pants feel.Maybe I can get some accelerometer data with the stock shackles going over a railroad track, and then after I install the Carli shackles.
Having someone else install due to my health. I appreciate the gesture.Are you installing the shackles yourself? If so I have an unused box of Sulastic's that I'd be happy to gift to you so you can compare and contrast. In the name of science, of course.
Bilstein 5100 steering stabilizer was installed today. The stock Ford one seemed trashed already at 26K miles; it didn't want to move back after compressing it with hands.
Steering wheel feels less sloppy if that makes sense. Can’t think of technical term for it at the moment.Did you notice a difference with it?
Like there's less lash in the system?Steering wheel feels less sloppy if that makes sense. Can’t think of technical term for it at the moment.
