- OP ๐น
- #801
Both OEM AC power ports now modified with 12 AWG stub outs and now ready to remove the '400W MAX' text next with the laser. I may not bother engraving '15A MAX' since the contrast probably won't be great.
Thank you! One of the metal clips from the center stack bezel fell off somewhere on the transmission tunnel I think, so will be pulling the center console trying to find it tomorrow.. Couldn't find it anywhere with the borescope camera and magnet. Ford's clips are pretty terrible and at least one never stays with the part that you're removing.Nice work @BroncoHooves![]()
Found that out with the center speaker cover in the dash. Luckily there is a nice "bowl" under it that caught it. Plastic clip, not metal, but same idea.Thank you! One of the metal clips from the center stack bezel fell off somewhere on the transmission tunnel I think, so will be pulling the center console trying to find it tomorrow.. Couldn't find it anywhere with the borescope camera and magnet. Ford's clips are pretty terrible and at least one never stays with the part that you're removing.
Yes! I had that same plastic clip fall into the bowl as well removing the speaker cover.. Wish the metal clip would've fell onto the floor thoughFound that out with the center speaker cover in the dash. Luckily there is a nice "bowl" under it that caught it. Plastic clip, not metal, but same idea.
I donโt think Iโd bother changing any labeling. You know what it can do, and no one reads those anyway! Haha. Great project!Both OEM AC power ports now modified with 12 AWG stub outs and now ready to remove the '400W MAX' text next with the laser. I may not bother engraving '15A MAX' since the contrast probably won't be great.
That's not a bad idea actually, it wouldn't stand out, would look factory at least and would be stealth?I donโt think Iโd bother changing any labeling. You know what it can do, and no one reads those anyway! Haha. Great project!
I love the stealth aspect!That's not a bad idea actually, it wouldn't stand out, would look factory at least and would be stealth?![]()
Great post! Anyone uncomfortable with electrical work should take their truck to a upfitter or vehicle shop who is licensed and bonded.Just a little warning for everyone following along.
12v power and 120v (and 12v 300 amp) power are totally different animals.
I have no doubts in Broncos abilities (and surely many others of us) but for everyone else, please make sure you know what you are doing before messing with 120v wires in your dash, under carpet, etc. Make sure things are fused properly. Make sure connections correct; and dry; and durable enough to withstand the vibrations of a truck.
12v 20amp shorts make smoke, 120v 20amp shorts make fire and can kill you.
Stay safe & carry on...
I prefer my screw heads to be horizontal than vertical! Just saying.......Added Nema 5-20Rs in the bed today:
Depends on the context on how I do it. If it's a kitchen backsplash with horizontal outlets, I will choose the slots to be in the natural direction of how the eye looks across the wall.I prefer my screw heads to be horizontal than vertical! Just saying.......
Ok, I won't bother you again, I can't win. LolDepends on the context on how I do it. If it's a kitchen backsplash with horizontal outlets, I will choose the slots to be in the natural direction of how the eye looks across the wall.
Are you essentially adding the same 2kwh power source as 2023 SD is promising or is yours fundamentally different?Two 5-20R splitter breakout cords, one for each side of the truck, arrived today. Should have most of my bases covered now.
Same 2KW and pure sine wave setup (at least I hope Ford is smart enough to do pure sine), but I am not losing space under the 60% rear seat like the 2023s are giving up with their inverter.Are you essentially adding the same 2kwh power source as 2023 SD is promising or is yours fundamentally different?
Any idea what the total cost of this is going to run you?Same 2KW and pure sine wave setup (at least I hope Ford is smart enough to do pure sine), but I am not losing space under the 60% rear seat like the 2023s are giving up with their inverter.
About $1K I figure (includes inverter and 3/0 welding cable, the largest ticket items)Any idea what the total cost of this is going to run you?
