Red Zeppelin Build
Did you take any pictures? I have the S&B as well. Also have done the upper, but not the lower. Was wondering how vulnerable the long fuel lines may be.
Less vulnerable than the plastic filter housing under the truck.
I would say with the S&B tank, the filter is pretty well protected anyway. But, the new lower filter lines (as you see in Broncos pics above) go over the frame and come down through the gap in the tank and connect. Very protected as well. I just like the convenience of not having to get under the truck to change the fuel filter anymore. I only have to get under it to drain the oil pan and lube the front axles. Otherwise, oil and fuel filters are easily accessible for me sitting on the ground at the sides of the truck. Love it. But I had no idea the fuel lines came down through the tank. I was super worried about running them below the frame. @BroncoHooves - you saved me some serious stress and potential future issues! Thanks a million!
This question is for either of you! I know Bronco has done this modification. I am assuming the 90 degree fitting that comes on the HSM upper filter will not accept the quick connect aluminum fitting, hence the reason for having to order the new 90 degree part. Thanks
If you're talking about the upper filter, no it won't work (reason for buying the extra fitting). No need for quick disconnects on the lower filter.
Yes, upper is what I was referring, thanks
Another question?? I am waiting for the 90 degree to complete the quick disconnect on the HSM upper filter injecter return line. I assume you used the same hose provided by HSM? Did you simply cut the upper threaded portion in order to accept the new "barbed" fitting? Lastly is that barbed fitting as difficult to install as the smaller one on the other end? Was lubricant for the barb necessary? If so what? Thanks!
Yes, you cut the old fitting off, but do not cut the hose too short!
Honestly, even with lubricant (diesel or petroleum jelly), it was extremely difficult and my thumb had a massive blister from getting the fitting inserted. I used a heat gun to soften the hose a bit and it was still difficult, much more difficult than the small barbed fitting on the other side.
Yes, you cut the old fitting off but do not cut the hose too short!
Honestly even with lubricant (diesel or petroleum jelly) it was extremely difficult and my thumb had a massive blister from getting the fitting inserted. I used a heat gun to soften the hose a bit and it was still difficult, much more difficult than the small barbed fitting on the other side.
WOW! I never did get the smaller one inserted completely, about 3/4 of the way, there is no way its coming out plus I clamped it. I noticed you did not clamp the top one, is that why? I don't believe the return is under much PSI.
There wasn't a need to clamp it, the 3 barbs took a metric ton of force to install.
Got more work done on the BuiltRight DIY bed divider. 2x2x1/8" 316 series Stainless angle pieces installed:
Thought about painting them but having some contrast may be good for safety when working/crawling around in the bed. All I have left to do is drill and tap for the 3/8 stainless studs and wait for the knobs to come in.
Added Vinyl caps to both ends of angle pieces as well. @Vecman
I like it. Excited to see the final outcome
Finally finished the BuiltRight DIY bed divider :D It works perfectly and offers plenty of room at the rear of the bed for a future fridge/cooler and beverages. @Vecman
Well done! So, those knobs actually screw into something correct?
