Red Zeppelin Build
Bronco that first part, the 90, is like 11.00, but 26.00 shipping, that's nuts. Going to call them tomorrow
Shipping to my area was like $11. Leakey is like $26 because it's considered a remote area by UPS.
11 is ridiculous...gonna call then. Put in a padded envelope, mail it for 5 bucks.
BuiltRight large rear panels installed.
Also started work on mocking up my DIY 2x12 bed divider idea, which will be sweet. (C clamp in pic was just to take a photo without the board falling over). The wood will be primed and painted black when it's all done.
I have some stainless 90º angle pieces on order. There will be one hand knob on each side securing the wood to the angle pieces, which are attached to the BuiltRight panels.
This offers me more room at the rear of the bed than the OEM bed divider or the stamped slots in the bed; probably enough room to have an ARB fridge, fishing gear, etc. I'll eventually have 12V ports in this same area.
Yep! Set Plain English 'Battery Type' to: AGM, and set Plain English: 'Battery target state of charge' to: 95%. Did a BMS reset as the final step.
Oddly, my 'Battery target state of charge' was 120% from factory setting. 🤔
I just did this installation as well. My truck is also at 120% How is yours working at 95%? Any reason why you didnt set at 100%
The documentation on this system isn't great, so I set it to 95% to have a little bit of a buffer to be safe. So far these batteries have been working great. The starter has more punch/juice when starting the 6.7L
After abandoning the idea prematurely, I've decided to pick back up on the OEM DRW rear tailgate light bar with a unique modification. It will not only be the normal running lights but will also double as a brake light. Just need the light bar to arrive then I can start testing the circuit.
Please please please. To me thats one major annoyance about oem drw rear light, i wish it acted as the break light more than a running light, a combo would be even better.
Yep. The more visibility the better to distracted texting drivers.
@BroncoHooves - did you do the lower HSM fuel filter? If so, and you have the S&B tank as well, can you post a pic of the way you routed the lines? I know there’s not a lot of options, just wanted to confirm something with your instsll
before I do mine. Or if you’ve already posted it here, just direct me. Thanks!
Here you go. Hose routing will be identical when I do the S&B tank install.
Holy crap I’m so glad I asked. I didn’t see the hole to bring the lines down through the tank. Oh thank goodness!
Yep! That is what this pocket/opening is for on the S&B tank, for those hoses.
Easy install! Thanks for the help!
Did you take any pictures? I have the S&B as well. Also have done the upper, but not the lower. Was wondering how vulnerable the long fuel lines may be.
Less vulnerable than the plastic filter housing under the truck.
