Bronco, any worries about this larger unit and it’s ventilation needs going into the factory spot? I was reading up on it and wondered if the underseat area allowed for good ventilation.
Not too worried about it since the built in fan will auto rev to the speed it needs to. I'll still do a load test and see if it thermal overloads. Worst case scenario, I can laser cut some slots in the seat bracket to give it more airflow.Bronco, any worries about this larger unit and it’s ventilation needs going into the factory spot? I was reading up on it and wondered if the underseat area allowed for good ventilation.
Haha. Very true, I thought about that as a worst case scenario. I’ll just keep following and see how everything goes for you. Love what you’re doing.Or, maybe just lifting the 40% seat bottom up when the inverter is on will suffice![]()
Or you've just added a seat heater booster for the person sitting on the 40% seat.Haha. Very true, I thought about that as a worst case scenario. I’ll just keep following and see how everything goes for you. Love what you’re doing.
Ok, questions?About $1K I figure (includes inverter and 3/0 welding cable, the largest ticket items)
I will be running 3/0 up through the floor with waterproof cord grips/glands (haven't got a chance yet). I have 30 ft of red and 30 ft of black 3/0 Temco welding cable that I bought just to make sure I had plenty of length. The manufacturer recommends 2/0 for up to 6 feet away from the battery, and the run will be at least double that, so 3/0 was chosen.Ok, questions?
You ran 3/0 to the inverter? How long a run was that? why 3/0? (it's not cheap).
It that run along the frame and up through the floor in the back seat?
What did you use for a fuse (& rating) and/or disconnect?
Really like the plugs in the bed.
Most likely I will be adding my in addition to the stock inverter.
Don't feel like futzing with the stock outlets & wiring & dashboard.
There will be a Littelfuse BMZF bolt down M10 300 amp fuse mounted at the battery. Photo below of the fuse holder/busbar. 300 amp was recommended by the manufacturer.
From the NTX-2000-12 inverter datasheet:Just curious if you know what the max amps that inverter will draw.
I suppose the difference here is that inverters can be constant, winches are not.
It's terrifying that people pull 350+ amp through 2ga wires.
That littlefuze BMZF busbar & fuse is very cool. Great for limited space.
Did Discount finally agree to mount them?New shoe day!
No, I would've got them to do it yesterday otherwise. Found a different place.Did Discount finally agree to mount them?
Thank you!Looks good
I think I like this way better than the glovebox.Was able to get the Midland radio unit mounted under the driver seat where I wanted it. I designed and printed a piece that clamps/sandwiches the radio bracket to the vinyl flooring. There was plenty of clearance under my driver seat for me to mount the radio here.
Tomorrow I will route the antenna and power wires to the base unit.
