Question about Oil Level
Not sure what everyone else is doing, but heres what i did with a 23. I cut the home depot bucket because on my stock lifted 23 the regular bucket didn’t slide in/fit easily. Now it slides right under perfectly and holds 15q of black gold just fine.
View attachment 133500View attachment 133501
This is what I do as well, but with the tremor and off-road running boards, I didn’t need to cut the top off the bucket. Slides right under (more space than my 2004 F-350 had). Use a large funnel to empty back into 5-quart jugs for recycling.
It's yellow molded plastic on a wire cable. Very similar to the beads on a Mercury outboard.
Thank you, that’s what it looked like to me exactly. It’s completely made out of metal (lead, or similar I believe) on my 2022.
Was looking through the 2024 owners manual (my pickup is on the train so getting a jump on it), and I noticed a good explanation of the dipstick marks that further supports the notion of not trying to fill the oil up to exactly the max level. Looks like 2023 and 2024 model years have three marks (not sure if prior years had this as well). Minimum, Nominal, Maximum. Nominal is the top of the crosshatch. Max line is above that. Definition of "nominal level" is the operating level at which something is designed to operate. The existence of the nominal mark further supports that there is no reason to try to fill your engine with oil exactly to the top of the max line with the risk of overfilling. The nominal oil level is the target level when doing an oil change (and even that doesn't need to be exact). No reason to spend a bunch of time slowly adding oil, waiting for it to run into the oil pan, check and recheck, add a little bit more, etc. to get exactly at nominal or max levels. Anywhere between half way to the max mark and max mark and you are good to go.
I'm finding that my '23 needs right at 16 quarts to be in the top 1/3 of the hashmarks.
They finally added more detail to the dipstick explanation, took them long enough. The previous generation just had this-Screenshot_20231117_091508_Chrome.webp
Edit- It actually looks like 2022MY was when they added the additional detail to the dipstick overview in the manual.
On your next oil change install a Fumoto oil drain valve. It allows you to drain the oil directly into an empty milk jug with a small hose for oil changes with no mess. Another advantage is the scenario that you have just described. If you are to accidentally overfill it, it's simply a matter of snapping the tube back on, putting a container under it and draining a little bit of oil out.
I have noticed that oil does seem to show up at different heights on the dipstick during back-to-back checks. It's kind of weird how does that. I have also noticed on my 7.3 that is only supposed to take 8 quarts that it takes 8 & half quarts to get it up to the full line.
Do you add an adapter to your fumoto drain valve? With the recessed drain plug my fumoto valve is unable to rotate out from under the oil reservoir. Little concerned if I go off road it could yank that valve open and drain the oil!
DA
DA
Honestly I don't remember and I don't have access to the truck at the moment. I may have as it does seem to stick out a little bit. I'm off road a fair amount and have never had a problem. It has that little clip that goes on it as backup and you either have to push up or pull down to get the valve to open. I'll try to look tonight after I get off work. After 11 oil changes, you'd think I would remember. Getting old I guess.
Just did my first oil change at 3100 mi on my ‘24. Put 15 qts in and barely read at the min mark. Drove it 100 mi or so and then the truck sat for a week. Came back today and figured everything had plenty of time to settle and the dipstick still shows at the min mark. Called 2 different dealers and they are unwilling to give me any answer for fear of being wrong??
I dumped another quart in, started the truck for a couple minutes and checked again. Now reading 1/4 way between min and normal. I give up.
I'm just going to say this : Did you add the recommend amount of oil ?? If it's 15 qts in....why are you feeling like the dipstick tells you the honest truth?? I can't recall the recommended time to read the dip stick (something like after sitting for 20 minutes of norma driving ??).
For myself : I change the oil adding what's recommend by the manual (13qts for my 2022). Shut the hood. Drive it 7,500-10,000 miles...change the oil, add 13 qts....shut the hood.....10k miles repeat...10k miles repeat...10k miles repeat. I can't tell you the last time I pulled out the oil dipstick for any reason at all.
On my 21' I have to use 8½ quarts to get it to the full mark. I've changed it 12 times now and that is what it has always taken. Can't explain why.
As I stated in the original post, yes. I filled it with 15 qts. I’ve added another quart for this simple reason: the engine takes a dump for whatever reason, gets towed to the dealership and the first thing they’re going to do is pull the dipstick and check the oil level. I tell them I’ve added the 15 qts as per the manual but it’s still sitting at the min level. Because I’ve done the oil changes myself they say sorry, you’re running at the min oil level, warranty is void.
Food for thought…
Food for thought…
So Ford says 15 qts....that's not enough....then the engine dumps...your not covered under warranty .....class action lawsuits abound over improper printing in owner's manual or improper design of the dipstick. Nah....not happening.
I think a lot of this is the way these new dipsticks are designed. Not to mention maybe people are running the motors prior to reading the stick. Hence the oil filter is absorbing a 1 qt of oil. So we play this game. Do what you want. It's your truck, you are not going to get any 100% answer that fits. So if you got to add 1-2 quarts on top of the 15 so be it. Others will add 15qts and be on the stick. It's what it is.
I find that 14 qts in my 2022 and 16 qts in my 2024 get it to about 3/4 of the way up the safe range. I use the Motorcraft brand oil and it could be that they are not really a full 5 quarts. I trust the dipstick more than the oil bottles or the owners manual because the physical level in the oil pan is what really matters the most and the dipstick should accurately measure that.
I have been long using another container to control the pour into the filler. I can say there's never been a time when any MC jug has not been spot on 5 quarts.
Container I use (spouts are listed in the selections below the product) :
Is it out of the question the dipsticks are wrong?
If the 5 quart jugs can be judged, yes...the dip sticks could be wrong as well.
Here is my opinion, although, the dip stick on my 2021 6.7 reads accurate with the proper amount of oil. If you have a Tremor 6.7, 20 thru 22 it's 13 quarts, Tremor 23 or 24 it's 15 quarts. If the dip stick is not reading full, be confident it is FULL.
