You are right, it doesn't fluctuate but it begs the question what is correct, the dipstick or the "official" capacity. Since Ford gives an official method of checking the oil level in the manual, I would lean toward that being the final say rather than a published value. Others have reported that MY23s+ take about 16 quarts to be at the middle of the dipstick so my experience isn't unique. It is possible that the dipsticks are wrong, but I find that hard to believe if many others are seeing the same thing. It is also possible the manual is wrong, and the capacity is without the filter which would bring it closer to 16 quarts total. I may buy another dipstick and see if there is a difference as they are around $30 last time I checked.
As far as the dipstick not being seated, I am certain it is as I check it multiple times to make sure the reading is consistent. After 1000 miles my '24 was right on the min of oil according to the dipstick. I stupidly didn't check it before that as it was a new truck so I don't know if it was always like that. When I changed it at 2000 miles, I put exactly 15 quarts in of MC 5w40 full synthetic and it barely registered. Added about half a quart and it was above the min and I ended up adding the rest and it is exactly between min and max. Been checking it about every 300-500 miles and hasn't changed in 2000 miles since.
