Question about Oil Level
Quick update…
First off, thank you very much to everyone who responded. The advice was helpful. I ended up draining about 16 oz (measurement courtesy of an 18 oz Solo cup), cycled the truck, and checked again. This time it came in right at the max line. That measurement makes me much more comfortable. I’ll check it again tomorrow when I return from an airport run. Thanks again!
I tend to run my vehicles 1/2 to 3/4 up the dipstick indicators. Less risk of overfilling. As long as your oil level is anywhere in the "good" zone, you are good. No reason to fill them right up to max mark. And, it's very fiddly to get it exactly to the top. It's never exact. Run it 1/2 to 3/4 up in the zone.
Like others, I reference the amount the vehicles manual specifies for "oil change with filter change". I dump in about 1/2 to 1/4 quart less than that amount, start the vehicle so oil circulates and fills the filter and oil warms up, then shut off and let it sit recommended amount of time, then measure with dipstick. If that first check is in the top half between the indicator marks, then I'm done and don't add any more. If in the bottom half, I'll add another 1/4 to 1/2 quart based on that level, let that pour drain down for a bit and check. Remember that when you add a bit of room temperature oil, it takes quite a while for all of that to drain down into the pan and give a valid oil level on the dipstick because it clings to the internals for quite a bit. Shooting for 1/2 to 3/4 between the dipstick indicators will avoid overfilling. There is no reason to be right at the max mark. An extra 1/4 quart of oil capacity (compared to the 8 to 14+ quarts of overall capacity) is not going to make a difference in how your oil protects or wears, with a modern oil, for a 5,000 - 10,000 mile oil change interval.
As for tracking what you are adding, even the 5 quart jugs have markings on the side so you know how much you've poured in. For 8 quart oil change, I slam in the first 5 quart bottle, then start on the next 5 quart jug, stopping after what feels like two more quarts. Set the 5 quart jug on the shop floor so it's level and you can quickly see remaining oil amount via the jug indicators on the side. If an 8 quart fill, I want about 7.5 quarts for the initial fill so that is 2.5quarts from this jug which means there will be 2.5 quarts remaining from that 5 quart jug. If, after I run and check dipstick, I need 1/2 quart more, I dump in 1/2 quart more. No need to transfer to a different container to measure the fresh oil since the container the oil comes in has the levels indicated already.
Don't try and bait me in.....I'm not that easy. 😜 😜 😜 :ROFLMAO: :ROFLMAO: :ROFLMAO:
and here I am, pulling you right back in.
Def prefill the filter, lube the oring, add oil till full line. Start, get oil pressure, wait a second, shut down recheck top off, send it till the OLMinder tells me to change it or roughly 7500 mi lol
True that. The other oils don't normally sell in 5 quart jugs?
To me this can be confusing to someone not paying attention or not knowledgeable that Motorcraft jugs are 5 quarts. Most of us on this forum are enthusiasts and are knowledgeable. But to the casual owner they can easily make the assumption they are 1 gallon jugs. Personally I don't understand Motorcrafts logic with doing it this way, as not until now with the 6.7 HO has the 6.7 diesel capacity been 15 quarts that would accept 3 five quart jugs.
...But to the casual owner they can easily make the assumption they are 1 gallon jugs...
Most oils for gas engines come in 5quart jugs: Mobil 1, Kirkland (Costco), Valvoline, Pennzoil, Castrol, Motorcraft, Quaker, Royal Purple, etc.
Most diesel oils are sold in 1gallon/4quart jugs: Mobil 1, Shell, Valvoline, Pennzoil, etc.
There are some oddballs, like Amsoil, that sell both their gas oil and diesel oil in 4quart jugs (no 5quart). And Motorcraft sells both gas oil and diesel oil in 5 quarts. But, I submit that anyone doing their own oil change is going to know what size oil jug they bought and how much oil they are adding...Or at least use the dipstick afterwards to discover their assumption of jug capacity was wrong and they will only make the mistake once. Ha.
In any case, oil jug capacity decisions are not based on oil capacity of vehicles. There are industry standard containers available; 1quart, 4quart, 5quart, etc. and they are used for a lot of other things besides automotive liquids like engine oil and antifreeze. Whether you purchase your oil in 4quart or 5quart sizes, the majority of vehicles on the road do not have an oil capacity evening divisible by 4quarts or 5quarts so you are using partial jugs anyway. So most people changing their own oil are used to using partial jugs and paying attention to how much they are putting into their engine during an oil change.
If there are vehicles that have an oil capacity evening divisible by 4quarts or 5quarts, it is likely a coincidence or, it would have to be a design decision by the vehicle manufacturer since oil jug manufacturers are not making various jugs sizes to match oil capacity of a vehicle. More than likely, the diesel engine using an even 15quarts was a coincidence. Engineers decide how much oil is appropriate. Commonly-available oil jug size does not play into their calculations.
Everything you said is correct and I am in agreement. I was simply stating our society today assume many things, and oil jug size can also be included. Myself with my 6.7, I always used 2 Motorcraft 5 quart jugs and 3 one quart bottles, therefore no measurements needed.
Gotta be careful with assuming the jugs are filled to the correct volume from factory. Just like how soap or water bottles at the store are filled more or less than others. I use a measuring jug for oil changes.
Of course! Lastly I always check levels once engine is run and settled for a few minutes! Can't wait to see you Nov 4th!
Gotta be careful with assuming the jugs are filled to the correct volume from factory....
Agreed, thought in the 30+ years I've been doing my own oil changes, I never found oil bottles that were so far off that I overfilled during an oil change, but perhaps that is due to my method. As noted in a previous post, I use the indicators on the oil bottles and initially dump in .5 less than called for by the owner's manual, run engine to warm up new oil and fill filter, shut down for needed amount of time, then check with dipstick. If oil level is between 1/2 and full on the dipstick, I don't add any more. If between the bottom mark and 1/2 full on the dipstick. I'll add .25 to .5 quart. No value in having oil level exactly at the max mark and so I don't fiddle around getting it there. At or above the 1/2 mark on the dipstick and I close the hood. With this method, no reason to measure into a different container. I'll reserve that for my dirtbikes since they only have 0.9quart capacity (and even on those, I usually go more by the oil sight glass than the measurement).
Good point, i thought about that too. But give a take an ounce or two, it should be within range. This time i carefully measured both before and after, and with 3 jugs i ended down the middle mark. Rechecked for a few days, all good. 15Q guidance is good for my 23. My 22 needed 14 quarts to get into the middle.
Not sure what everyone else is doing, but heres what i did with a 23. I cut the home depot bucket because on my stock lifted 23 the regular bucket didn’t slide in/fit easily. Now it slides right under perfectly and holds 15q of black gold just fine.
Is that a plastic end on the dipstick they’re using now? Better contrast would be the reason.
Not sure what everyone else is doing, but heres what i did with a 23. I cut the home depot bucket because on my stock lifted 23 the regular bucket didn’t fit. Now it slides right under perfectly and holds 15q of black gold just fine.
A 5 gallon bucket would be convenient and, because it's tall, less splash. Seems like it would be a handful moving that once full and when pouring into a container to take to recycling. Huge funnel, maybe? Definitely not as many oil change container options when dealing with 15quarts all at once. Us gasser owners have it easy! Ha.
It's yellow molded plastic on a wire cable. Very similar to the beads on a Mercury outboard.
