Question about fog light amps- 23+ trucks
Mtnduty
Non Tremor Tremor Club President
Arizona / Colorado
25' F250 Lariat Fx4 7.3 Godzilla
I'm trying to get clarity on how much power the OEM fog light switch and wiring can handle. From my research it seems to me that since they are directly connected to the BCM, they share a fuse with the BCM itself? Am I understanding that correctly?
Essentially what I want to know is this- I am adding 2x lights to replace my OEM LED fogs, these new lights produce 4.77 amps at 12.8 volts each... should I just wire them to an aux switch to be safe? I have no problem with that- I am just running out of aux switches and don't want to use one if I don't have to.
Been searching for a few hours and only finding answers for older trucks.
Well the OE circuit pushes two BD fogs. So at least 2.5amps (29watts)
Yea- I was running two baja sport fogs in my OEM bumper. The jump from 2.5 to 4.7 is what has me pausing. I know some guys run the squadron pros which I believe are 3 according to their website so a little closer but still a bit off.
I ran 4 bd’s, something like 12amps total just fine.
Wired to upfitter or all into the fog circuit?
All on the fog circuit. I changed it later but it ran all 4 lights just fine. Eventually put the pro’s and the XL80’s on the A pillar to an Upfitter just because of how bright the pro’s were. And even with the fogs off if you turn a corner they turn on so it was a little awkward.
Ah yea I have that whole fog corner thing disabled- I hate that feature lol
(Assuming LED fogs) The fog lamps on the 22MY are driven through FETs from the BCM, and the source is through the Control Junction Box (CJB) through a relay with a 15A fuse, F17. (Likely similar for the 23 and up) The FETs are generally capable of sourcing around a working current of 10A (peak at 70A). You can probably get away with running 9.5A, but to be safe, I would use a relay harness as is usually received with most light kits. This will add the 40A relay and you can run as many lights as you want without worry. (Typically, up to around 25-30A total per relay) The lamp source will be directly from the battery, and the trigger will be the fog lamp signal or the switch that is generally incorporated into the harness. (Your option)
The incandescent or halogen light version may be different, it appears these have 40A fuses for each lamp and sourced from the Battery Junction Box. (BJB)
Does the BJB work through the CJB while the FET is running? I could've sworn this was a question on my SAT's but I was MIA 🤪.
The BCM is the control for the LEDs and Halogen versions through FETs. The source for the halogen is from the BJB, the source for the LEDs is from the CJB via a relay. (According to the block diagram I have.)
Some of the lamps such as the high mount lamp, is driven from the same FET from the BCM, whether it is FET or incandescent. But the fogs show a different path likely because they would have to use a higher current requirement for halogen lights. I don't have all of the part numbers for the different FETs; I can just see that the drive source is definitely different. I also don't know if the FETs in the BCM are different for the FET vs. The halogen. But the drive path circuitry through the BCM seems to be the same.
The Source which is hot at all times when the fogs are enabled, is the real difference; one feeds a higher current than the other. The FET in the BCM is the "grounding" switch. (Completes the path by grounding the negative side of the lamp.)
Edit: Ooops, backwards: The FET's switch the hot on through the BCM, ground is always intact.
I feel much more positive now and will check my BMI tomorrow, thank you! It's probably over 30 and need to go to the GYM 😁.
using the stock circuits to run a relay
perfect!!!!!!
you'll have to run the lighting power but unlimited what you can run on the stock fog switch this way
same thing with the low power upfitters
bravo!!!!
@Canyon Trekker
bravo!!!!
