Oem screen conversion
ok so i had about 2 hours to drive it around.
cons
heated seats don't work
no audio when is start the truck, fm am or andriod auto(aa) reset the the apim ( power and next track button) and it works.
no full screen option for aa
no climate info on the screen
pros
no wandering gps (vertically mounted)
heated steering works and all climate controls work
i saw some lariat owners with climate on the dashcards panel (right of screen) i enabled them in forscan but got nothing in the truck.
I have revision 243. anyone have these issues w. other revisions?
Climate doesnt work on my 24' F-150 on the Sync4 display either. Not sure why that's a big deal when you have all of the physical buttons
-snip-
Now could anyone who has had the programming done, be able to check whether your rear defrost/heated mirrors are working? This is the last issue i have with this upgrade. Trying to determine if it is the module I bought. I have a suspicion it might not work at all though....
So the FS4 tech says that the defrost not working is a harness issue, they have "talked" to Ford about it and are working on a new one. I have my doubts (that they actually talked to Ford, or that a harness could solve the issue), but I guess I will wait and see. Of course the ETA is 1-2 weeks.
How do you know when your fan is running? No light on the power temp knob.. or other indicator it's on
cons
pros
Have them connect to your truck, they fixed most of the climate issues as far as climate control on the screen they said that it’s not possible as of now. Before I had them connect that I have vented or heated seat controls, or any climate controls almost everything got fixed by them.
i did, they cant get it work. was told they should have a fix by the end of the month at the earliest.
any lariat owners have dtc's for bdycm, and acm for lost comms with apim?
Getting close to two weeks since I talked to them about the current issues that I am dealing with. The reply was that they are getting a technician to reach out to me. I haven’t heard anything back and I checked in twice since then and they keep replying with the technician will be with me. I certainly don’t think this is enough for me to go back and ask for my credit card to dispute the charge, but I would like them to at least fix the issue or if they can’t fix the issue to give me some sort of money back.. Just for reference I bought this early November.
SYNC4 or Infotainment?
Hello, I have joined this forum since it seems to be one of the only places actively discussing this upgrade. I MAY be able to help?
@bbrett there is a setting in the APIM for multi camera strategy
7D0-01-01 xxxx xxxx xXxx enable hardbutton camera toggle
DAFVC Split View (DAFVCSV) • Multi Camera Strategy (MCS) • Trailer Reverse Guidance (TRG) • CHMSL Camera (CHMSLC)
0 = DAFVCSV Not Available • MCS Hard Button Camera Toggle • TRG Disabled • CHMSLC Disabled
1 = DAFVCSV Not Available • MCS Hard Button Camera Toggle • TRG Disabled • CHMSLC Enabled
2 = DAFVCSV Not Available • MCS Hard Button Camera Toggle • TRG Enabled • CHMSLC Disabled
3 = DAFVCSV Not Available • MCS Hard Button Camera Toggle • TRG Enabled • CHMSLC Enabled
8 = DAFVCSV Available • MCS Hard Button Camera Toggle • TRG Disabled • CHMSLC Disabled
9 = DAFVCSV Available • MCS Hard Button Camera Toggle • TRG Disabled • CHMSLC Enabled
A = DAFVCSV Available • MCS Hard Button Camera Toggle • TRG Enabled • CHMSLC Disabled
B = DAFVCSV Available • MCS Hard Button Camera Toggle • TRG Enabled • CHMSLC Enabled
Hopefully this helps.
@Chippy45 you have had programming done with the FS4 tech yes? Did they program the HVAC module? To access the HVAC module you will need a profile from a vehicle that comes equipped with one since Forscan will not read it otherwise. I have attached a Bronco profile they used to program mine (change the file extension from txt to profile). Import it into Forscan. Try to connect with Forscan with ignition off, choose the Bronco profile and hit OK, then turn the igntion to ON (engine off). It should load and try to read modules (many your vehicle doesn't have and will error - ignore them). You should now be able to access the HVAC module (HVAC module should not error - may have DTCs).
733-01-01 xxxx Xxxx xxxx C --> front h/c (externally controlled), does not contain rear climate seats | D --> front h/c (externally controlled), does contain rear climate seats
733-01-05 xxxx xxxX xxxx 8 --> front h/c, no rear conditoned seats | 9 -->front h/c, rear seats heated | A --> front h/c, rear seats heated and cooled
Welcome and thanks for all the info!
Holy shit @bbrett that looks fire! You going to do the door card trim too?
Yea already done, will post some photos later. Doing the center console shifter conversion today with the raptor carbon shifter
That's cool. Had that in my 2018 f150. Much rather have the SuperDuty for the extra cup holders/storage.
Finally broke down and just bought a used APIM off Ebay. Cameras and everything else work now, with the exception of soft camera buttons on screen and controls for massage seats. FordSync4 is adamant that I have the correct lower left trim bezel piece but It does not fit properly, I will have to cut the top out of my trailer brake controller mount on the stock dash parts. Really wish they would just send me the piece like @bbrett has but they just keep saying I have the correct part.
I had to go back and fourth with them till they finally said they would. I sent them pictures of it not fitting, with the bezel they send and also stock photos of a 2022 F250
here's the latest email I got, looks promising at least they think they think they found the issue:
Hello and thank you for contacting us at Infotainment.com,
We are reaching back out to update you regarding the "Apple Car-Play & Android Auto to Settings page" issue you've reported and as per our Ford service lead, the screen glitching is being caused by the accelerometer sensor that is responsible for the lane keeping assist feature functionality.
Our Ford lead is currently working on a genie solution to solve this effectively or figure out the best way to program this through ForScan and as soon as that is ready we will be sending that out to you if not scheduling a remote programming service for the ForScan programming.
We still appreciate your patience throughout this process and look to get you situated as soon as we can.
Respectfully,
Joshua
Have you had any progress with Infotainment?
So, I finally heard back from them. They have never replied to my actual emails, but I copy and pasted my email into their chat, and I got a reply on there.
The tracking number they gave me with the “third package” with the audio and HVAC controls, is the same tracking number they gave me for my “second package”.
I told them I want a refund yet, will see what their next reply is before I start a chargeback.
Following up on this too, they never did reply to me. I initiated a chargeback on Feb 27 and it finally was completed 4/30. Going to guess FordSync4 completely ignored credit card company because there was no info in the subject, just that my chargeback credit is now permanent.
Now i have this whole radio set sitting here that idk what to do with now.
What did you do just copy all the same stuff on the APIM and just transfer it over to the OEM APIM?
