Oem screen conversion
Another thing, they were worse to respond than FordSync4 which surprised the shit out of me. As soon as I first started having problems they became extremely unresponsive. And then when I went through for a return it was just as bad.
Yikes I would not expect that from infotainment.
All right guys, it looks like I’m as close as being complete as I can be. I went out for a 4 Hour Dr. the other day and I noticed that my GPS wanders randomly. All I have to do is restart my radio, and it starts working normally again, no issues. The one thing that I will say is super annoying. Is that the screen randomly just blacks out. I could be mid drive or listening to music and it would just turn black radio still works Apple CarPlay still working but the screen is completely black to fix this. I could either wait for it to just turn back on and sometimes it could take 30 seconds or five minutes. Or I could just restart the whole radio. Does anybody have a solution for this?
The gps wonder is somewhat fixable. Mine doesn’t wonder if I drive straight. Making any turns and then it gets confused. The screen turning off. I don’t have an answer.
I returned it also.
XM and Sirius did work. Infotainment sells a kit to make it work.
The issues I had were:
  1. Door keypad code programming does not work
  2. Vehicle alert sounds dont work through door speakers (only comes through the tiny little speaker to the right of steering wheel)
  3. I have a weird crackling sound that started.
    Only does it on FM radio. Even at volume 0 still crackles. Never did it with sync 3 head unit
  4. 360 camera button non functional. (They say they got this fixed and have to update my radio)
5. This is probably the biggest one, my radio will go to settings on its own. Sometimes in 5 seconds, sometimes it takes 5 minutes. It will just go to the settings page. It'll kick me out of CarPlay and go to radio settings.Entirely in its own. This is the most annoying one because the radio just ends up in settings ALL THE TIME
On another forum, another guy was having the same issues with the settings screen thing happening. Infotainment could not replicate it and it basically made the screen useless.
I am having the same issue on items 4 and 5, I'm gonna give them some time. I talked with a Joshua on the phone, he said the ford programmer is working on this for item 5 and for now they are extending my warranty. my issues are the display settings switching both in the xm, or radio screen, or carplay screens to swithc to the random screens (although they mostly switch to the setting page), seems to be an issue that multiple people are having and they are working on a fix, it sounds like in the near future, not 6 months down the road. my screen will also randomly lock up and not allow me to use the touch screen, but the manual buttons work fine below the display or the steering controls. They hope to have a fix that they can push via the DIY OBD Genie Mixed Mode Programmer that they can send out and not have to send back the APIM module.
I was dealing with a guy named Taylor, and he told me at least as of like 3/20 that they were not able to replicate the settings issue.
My guess is it's the aftermarket screen they send with them vs OEM. Prob just cheaper components.
These kits comes with a counterfeit apim. One I was sent has bad castings marks philips screws on the back vs hex oem and looks like it was spray painted silver.
Another thing is it gets hot. 15 minutes in the car and I got 123°F
My guess it might be over heating?
Good catch. I’m not lie I would not have thought that they would send out take a PIM. They look pretty inexpensive on eBay.
As far as heating issue, I’m pretty sure the OEMAPIM gets hot too, something I noted when I took my OEM out when I was switching everything out. I think it’s possible it could just be the screen if that’s the case I might just switch it out with one. I already have extra.
Are you having a similar issue?
I think it's 1 of 3 issues the cable, screen, or apim. Your audio didn't get interrupted bc its going through the acm. Let us know if the screen fixes it 🤞
-I haver had time to test it, I will def report back with updates.
First issue I have is the call steering wheel controls don't work in AA. Call p/u or drop buttons don't do anything
Only issue I have had is the wandering - but I haven't had my truck long enough to move it vertically yet. If I'm lucky I'll have my truck back in 2 weeks. :/ but when I was driving it everything worked just fine except toggling between camera views with the hard button. When I put it in reverse it shows 360 and rear camera, if I hit camera button while driving it shows the bed camera. I'd like to be able to toggle between views.
When I did get to use it for a few weeks, those were the only 2 issues I seemed to notice which seemed to be easy remedies.
wondering if you could buy an OEM APIM off eBay, save your perimeters from the Sync4 clone and import them to the OEM? Not that I'd spend the extra money right now if mine works fine, but if ever any issues if that would work.
Bbrett, have you tried change the APIM orientation parameters via Forscan? Some guys are having luck doing that if its mounted flat/horizontal.
To mount the APIM on the FS4 bracket with provided hardware, you will need to modify 7D0-07-02 - XXXX-****-XXXX, changing it to 0000-AFC8-00XX.
Thanks for the heads up. I'll have to give it a try when I get my truck back in about 2 weeks.
I'm trying to figure out how I can get the Bed/Cargo Camera Tile to display the bed camera if possible like the 2024's do.
I'm trying to figure out how I can get the Bed/Cargo Camera Tile to display the bed camera if possible like the 2024's do. View attachment 204370
Oh that’s sweet! I need to add that camera to my truck.
I wish I knew a few days before I cut the bracket and mounted it vertically.
here's the latest email I got, looks promising at least they think they think they found the issue:
Hello and thank you for contacting us at Infotainment.com,
We are reaching back out to update you regarding the "Apple Car-Play & Android Auto to Settings page" issue you've reported and as per our Ford service lead, the screen glitching is being caused by the accelerometer sensor that is responsible for the lane keeping assist feature functionality.
Our Ford lead is currently working on a genie solution to solve this effectively or figure out the best way to program this through ForScan and as soon as that is ready we will be sending that out to you if not scheduling a remote programming service for the ForScan programming.
We still appreciate your patience throughout this process and look to get you situated as soon as we can.
Respectfully,
Joshua
I know. I did mine vertically but I ended up still needing to adjust this parameter for my GPS to work right. I had to use a different setting that one the I put in my post. So if you’re having issues, let me know and I’ll send you the details.
ok so i had about 2 hours to drive it around.
cons
heated seats don't work
no audio when is start the truck, fm am or andriod auto(aa) reset the the apim ( power and next track button) and it works. fixed
no full screen option for aa
no climate info on the screen
pros
no wandering gps (vertically mounted)
heated steering works and all climate controls work
i saw some lariat owners with climate on the dashcards panel (right of screen) i enabled them in forscan but got nothing in the truck.
I have revision 243. anyone have these issues w. other revisions?
