Hello, I have joined this forum since it seems to be one of the only places actively discussing this upgrade. I
MAY be able to help?
@bbrett there is a setting in the APIM for multi camera strategy
7D0-01-01 xxxx xxxx xXxx enable hardbutton camera toggle
DAFVC Split View (DAFVCSV) • Multi Camera Strategy (MCS) • Trailer Reverse Guidance (TRG) • CHMSL Camera (CHMSLC)
0 = DAFVCSV Not Available • MCS Hard Button Camera Toggle • TRG Disabled • CHMSLC Disabled
1 = DAFVCSV Not Available • MCS Hard Button Camera Toggle • TRG Disabled • CHMSLC Enabled
2 = DAFVCSV Not Available • MCS Hard Button Camera Toggle • TRG Enabled • CHMSLC Disabled
3 = DAFVCSV Not Available • MCS Hard Button Camera Toggle • TRG Enabled • CHMSLC Enabled
8 = DAFVCSV Available • MCS Hard Button Camera Toggle • TRG Disabled • CHMSLC Disabled
9 = DAFVCSV Available • MCS Hard Button Camera Toggle • TRG Disabled • CHMSLC Enabled
A = DAFVCSV Available • MCS Hard Button Camera Toggle • TRG Enabled • CHMSLC Disabled
B = DAFVCSV Available • MCS Hard Button Camera Toggle • TRG Enabled • CHMSLC Enabled
Hopefully this helps.
@Chippy45 you have had programming done with the FS4 tech yes? Did they program the HVAC module? To access the HVAC module you will need a profile from a vehicle that comes equipped with one since Forscan will not read it otherwise. I have attached a Bronco profile they used to program mine (change the file extension from txt to profile). Import it into Forscan. Try to connect with Forscan with ignition off, choose the Bronco profile and hit OK, then turn the igntion to ON (engine off). It should load and try to read modules (many your vehicle doesn't have and will error - ignore them). You should now be able to access the HVAC module (HVAC module should not error - may have DTCs).
733-01-01 xxxx Xxxx xxxx C --> front h/c (externally controlled), does not contain rear climate seats | D --> front h/c (externally controlled), does contain rear climate seats
733-01-05 xxxx xxxX xxxx 8 --> front h/c, no rear conditoned seats | 9 -->front h/c, rear seats heated | A --> front h/c, rear seats heated and cooled
Now could anyone who has had the programming done, be able to check whether your rear defrost/heated mirrors are working? This is the last issue i have with this upgrade. Trying to determine if it is the module I bought. I have a suspicion it might not work at all though....
