Oem screen conversion
Post morning commute update. A/C button does not work only blowing the fan. Radio controls no longer working. Wondering if it a fuse somewhere for the radio controls, initially was working when i test fit it.
Overall install was ok, none of the correct size screws provided had to dig around in my barn to find stuff that worked. Left lower trim bezel sucks, does not line up correctly, trailerbrake controller pushes on its oem housing and the holes for the console don't line up well at all. Main bezel I had to beat into submission to get it to seat properly. Now I have to take it all apart to see why the radio controls stopped working.
When you are in there do you mind snagging some pics for us peasants
@BroncOh can you snag me the part numbers for the center console floor mount bracket and screws? Those buggers where loctited in bad and I broke one screw and cross thread anther trying to get it back in. Going to have to pull the console again when I'm doing sound treatment and will fix it while I have it out again.
I checked my extra parts stash and I didn't have any, otherwise I'd send them to you.
Front of vehicle bracket: FL3Z-96625A80-B
Rear of vehicle bracket: HL3Z-96625A80-A
Bolts: W711390-S450B (pack qty is 4, however some dealers will open the package and sometimes only ship you one)
Thanks!
So, I finally heard back from them. They have never replied to my actual emails, but I copy and pasted my email into their chat, and I got a reply on there.
The tracking number they gave me with the “third package” with the audio and HVAC controls, is the same tracking number they gave me for my “second package”.
I told them I want a refund yet, will see what their next reply is before I start a chargeback.
Radio control wire was unplugged. Still no a/c button I think I bought a bad used module. Relocated and zip tied camera module To frame under apim. Shoved acm as high as it would go and zip tied it up where camera module was.
No none of the extension harness for that match my acm. Still no ford pass connection or WiFi working. Going to play with forscan myself a bit tonight
Keep us in the loop ✊🏼✊🏼
Is this upgrade worth all the bullshit?
Just like with the Mach-E screen I can't get forscan to read the APIM. @bbrett when you were doing the remote programming session where they able to access the APIM and what version of Forescan were you running?
Based on their feedback so far...not yet. It has potential, but at this point, they are all beta testers helping with development. I'm watching closely but am waiting until it's all sorted out.
The infotainment option has been flawless for me.
Just my personal taste, I wish they made it look better. Definitely better customer service and plug and play compared to this Chinese stuff. The only reason I'm determined to make this work is looks if i can't get it to work I'll just bite the bullet and find a pulled dash. I'm buying my own harness from that thread on f150 forums I posted and going to see if I can get it to work myself and get rid of the all the unnecessary extension. It should just be pulling 2 pins, adding 1 and pulling ground and 12v for the Screen power and radio control power
I was very interested in doing this upgrade so I’ve been following this thread. The guys here are a lot more knowledgeable with this behind the dash stuff than I am. I’ve installed and/or swapped out stereos, TV’s, speakers, other accessories and electronics, etc in my Excursions and many other vehicles and have installed $20K marine navigation systems in my own boats and for other owners too for decades, and I’ve never encountered the bugs (and frustration) like have been shown in this thread. I appreciate what everyone is going thru and the sharing of very valuable info!
So far, I am 50/50 on continuing to want to do this upgrade. For me, it’s not a necessity, but I like to keep current. To a certain extent!
Hopefully everyone gets their systems up and running as designed!👍
They were able to connect to the APIM just fine, the POS OBDII adapter they sent didn't work so I bought a known working one on Amazon and had no issues.
They were able to connect to the APIM just fine, the POS OBDII adapter didn't work so I bought a known working one on Amazon and had no issues.
I'll attempt my own harness while I wait for their updated one with correct acm harness so i can get rid of all my zipties
Let us know what you end up changing on the harness, maybe you might get it correct 100%
We'll see what the new harness looks like that they send me. My guess is it still wont have the correct connectors to extend the ACM. I get the infotainment system works "flawless" it still to me looks like something I had in my Honda civic 20 year ago that flipped out of the dash like Brian O'Connors Eclipse. They are doing the exact same thing with a recycled ACIM/Aftermarket Screen, Forscan and their own harness. They just kept it simpler by not using newer A/C or Radio controls. I like how Sync4 at least tries to make it OEM. I feel if they were a US based company they'd be more successful. I'm not upset that something that was not designed to work with my truck doesn't work correctly, I'm just disappointed with the communication. I went into this with an open mind after @esw004 shared his MACH-E Screen conversion attempt with us knowing it will probably not be perfect right away.
My thoughts exactly!
