Featured
- #261
What type of issues are you guys running into?
Communication, and them sending everything complete.
This is very helpful, since their harness doesn't completely work with late 20+, the radio controls dont work still and it's like pulling teeth to get an answer other than we will look into this. I think this should help me get power to the radio controlsHere is the documentation from a dash swap I was able to snag off the f150 Forum before he deleted these comments. Might help you track down the correct pins and wiring. I'm waiting on my radio controls to attempt the install.
Can you confirm that your current set up does not allow you have radio controls? I have a 2020 just like you and I have the ability to control my radio with the toggles. HVAC works fine. My screen just won’t power on. Looks like they’re tinkering and trying to adjust the wiring harness little by little.
Chat them on the website, thats how i have been communicatingI've been reaching out to them for the past 2 weeks and I haven't got a response.
No. I doubt they will. I got the kit when it was on sale for $1400. Even with paying for the extra parts it’s cheaper than a dash swap from what I could find on marketplace. So I’m cool with not getting money back as long as I can get it to work. All the dashes I found for a swap are like $3-5kDid they refund you for this?
Harness fits everything. I do have two plugs that dont fit into anything. My audio controls work perfectly fine and are backlit. Ac controls work besides the vented/heated seats. Did you mess with the harness at all? Like repin stuff?Everything works but my radio controls, they won't power up (Controls, have no back light or don't control). Did all of their harness plug into your ACM etc? I had the same issue where it wouldn't power up. If I left my stock harness plugged into the ACM then the screen powers up fine since the harness they set didn't extend or fit in my ACM (Audio Control Module)
If you message them on the website chat with your order number they respond. They messaged me yesterday
I am using the harness that they provided and whatever else doesn't attach to the harness I plugged into the acm. Attached are the pics of the two wires on the harness that dont plug into anything(2) Plugs which Two? Did you remove your double din ACM or did you leave your original harness plugged into it?
Mind sharing a picture?
Misspoke on ACM. Meant to say whatever does not go into the harness I just plug it into where it fits.Those are the ACM harnesses, those go in the previous gen f150 and lower f250s. APIM and ACM are two different things. That’s what issue I’m having but you said your radio knobs work?
Just checking, you said using your stock ACM plugs instead of their harness is what powered up the LCD radio screen?Everything works but my radio controls, they won't power up (Controls, have no back light or don't control). Did all of their harness plug into your ACM etc? I had the same issue where it wouldn't power up. If I left my stock harness plugged into the ACM then the screen powers up fine since the harness they set didn't extend or fit in my ACM (Audio Control Module)
Per my notes I found on that dash swap on the F150Forum, if your Radio controls aren't powering up make sure that there is a wire out of Pin#44 on the APIM to the radio control harness. I can't figure out from his posts exactly where it goes on the radio control harness but that's my best guess on your issue. Still digging through other posts to see if I can find anything else. I'll update this comment if I find anything additional.This is very helpful, since their harness doesn't completely work with late 20+, the radio controls dont work still and it's like pulling teeth to get an answer other than we will look into this. I think this should help me get power to the radio controls
I attached the radio control plug from the harness. Where it connects from is basically to the APIM but it’s in a jumble of wires. If I show you that it might confuse you even more hope this helps.Per my notes I found on that dash swap on the F150Forum, if your Radio controls aren't powering up make sure that there is a wire out of Pin#44 on the APIM to the radio control harness. I can't figure out from his posts exactly where it goes on the radio control harness but that's my best guess on your issue. Still digging through other posts to see if I can find anything else. I'll update this comment if I find anything additional.
Also, here’s a picture of the ACM wiring harness forgot to send it to you
This is the wiring mine has on the back so those do not connect to the harness. My trucks a 2020The ACM look like this. So the harness you said you have extra connectors is suppose to go into this unit,
Yep mine was the same way, where did you put your ACM? I had to stretch those wires and shove up as high as I could so the APIM bracket would fit to get everything to close up. It wouldn't attach to the APIM screen bracket since the OEM harness that plugs into the ACM is so short. Once I plugged back in my ACM the screen powered right up.This is the wiring mine has on the back so those do not connect to the harness. My trucks a 2020
I did the same thing you did, I couldn’t attach the ACM to the bracket. Once everything works, I plan on just a zip tie and everything in place so it’s not moving around. I’m still scratching my head on why my screen doesn’t work. I’m starting to think maybe the screen is broken.Yep mine was the same way, where did you put your ACM? I had to stretch those wires and shove up as high as I could so the APIM bracket would fit to get everything to close up. It wouldn't attach to the APIM screen bracket since the OEM harness that plugs into the ACM is so short. Once I plugged back in my ACM the screen powered right up.
They said they need to make an extension harness so I dont have to do that, but they haven't made one yet.
