Oem screen conversion
Anyone doing this kit be VERY careful with your dash pieces, since the plastic pieces are made by them cheaper than OEM they clips are very fragile and can easily break. When you open the package the scent of fresh spray paint lingers from when they painted these panels. The also will scratch very easily.
I received my second package from them today. I also received the wrong trim bezel. Also still missing the radio and A/C controls.
Sounds like a bunch of fucking idiots over there.
How can you tell if it’s the wrong trim piece?
because the 150 trailer brake controller on pro trailer knob are swapped vs the f250. The F250 DASH has a square cut out for the trailer brake and a round for the trailer knob. Behind the bezel the dash is different too
See the two pictures
Yep, they end up sending ordering them off eBay and give your address..
Infotainment's kit they are also clear in their description that they sent you refurb parts as well
It has a coin slot.
More than just that, that's why I posted the details above, the F250 trim piece they sent had a coin slot I pulled out and threw away.
Hopefully they send the correct part soon. Doesn't seem likely though.
2-3K and you don't even get all the correct pieces after months of back and forth. Then you have to source your own parts to replace the incorrect stuff they sent if they even sent you all the parts in the first place?
I would've given them a few weeks to get it sorted before I did a charge back and told them to feel free to send a prepaid label if they want the random parts back. No way would I run around sourcing my own parts on such an expensive "kit".
So lets put this all out there, between infotainment and sync4
-Sync4 and Infotainment use OEM/Used APIM that's updated and re-flashed in for scan
-Both brands are using used or aftermarket screens
-Sync4 at least attempted to make it look OEM vs infotainment made the screen float and you're using your existing controls. (just looks like an after thought)
-Sync4 has terrible communication, but isn't vaporware like everyone thinks. They are a full Chinese company I feel that grew faster than expected, put a product out before they had all the answers and can't keep up.
-Infotainment is a US company with an actual number to call, I think if Sync4 had support they would be a little more successful.
Don't get me wrong, I'm beyond frustrated with sync4 as my radio controls still aren't working, I have a late 2020, so the harness and ACM is different that earlier trucks so they harness was designed for early 2020 and down. They don't respond and still don't have a resolution. I'm about to file a claim with my card company if this can't get this figured out.
This is a concern for me as well with a 2021 truck.
It's cool that they are trying to get it figured out but they need to stop selling kits if they can't even get existing customers sorted. Take backorders if they want but continuing to sell kits and then not being able to fulfill orders completely is going to kill their business faster than just suspending sales for a short time to catch up.
I hope they get you sorted and that it works out for you.
Let me know how yours goes. Their harness wouldn't plug into my ACM (Audio Control Module) because the harness is COMPLETELY different. So they instructed me to bypass keeping factory harness plugged into ACM, but with that the factory harness is to length, and you have to move your ACM in order to fit the APIM on their bracket. With that being said it was not an easy task, having to cut zip ties, re-routing harnesses, putting unnecessary pressure etc. I think this is the reason the radio controls don't work because I think the power comes from their pass through harness.
Hopefully you don't have the same experience, I know its not an issue with the physical controls because I bought a new set and still didn't get power, I even metered the wires and its getting no voltage. It's been 2 months since I brought this issue to their attention and still no resolution. Luckily I can use my steering wheel controls to adjust volume but still frustrating.
I'm curious if infotainment could help find a solution with their harness. They are pretty much the same products doing the same this as far as hardware goes as far as I can tell other than controls.
Well I couldn’t wait until the weekend to install the infotainment setup. It was all plug in play like their video showed. Good solid quality plastic housing and bracket. Everything appears to work out the gate too. Volume knob, climate control, heated steering wheel. The only thing I haven’t tested yet is SiriusXM and GPS because I didn’t take it out side.
Very happy with this TBH. Does not look as bad as I thought it would. With good customer support. I think FordSync4 product is going back.
View attachment 196487View attachment 196488
seeing your pictures I'm not mad at it at all. Looks pretty good. If Sync4 can't get me what I need I'll see if infotainment will send me their harness, brackets, bezel since I have everything else already,
I would be interested to see if infotainment could help find a solution.
I reached out and their customer service seems to be useless, I'll call them this is just through their email. Like the don't even read the emails. But I'm sure they won't separate their kit which I understand.
I didn’t have any luck with email either. I called their 1800 number and opted to start a text comvo with someone. Had a real nice human back and forth with someone.
