Oem screen conversion
Still scratching my head, everything works completely fine all the controls, but my screen does not power on at all. I used a new screen and it still doesn’t work. I tested power to the screen and it is receiving power. Any ideas?
Get an oem pink cable. Mine was very difficult to remove. I had to use a screw driver to press on the top then I pulled.
I just ordered the kit this last weekend. The site mentions remote programming sessions. Reading through comments here, do I need Forscan for these sessions or are they programming it remotely somehow? No where do they mention that Forscan is needed and I'm a bit annoyed as I do not have a PC (Mac household) or the needed cable.
They send you the cable for connection. As far as having a Mac, I have the laptop, but I also have a Windows desktop so I literally moved my entire desktop into my garage. Forscan is free, they send you all the instructions on downloading it and then also downloading team viewer.
I think the remote session is if something is wrong with your set up. I am hoping that they are going to fix this and have it down to a science sometime soon so remote access will no longer be needed only in rare instances.
Thanks. Cool that they send you the cable. Ok, I'll start working on a solution for a PC.
Going to double check all connections when I attempt sync3 ford pass reset once weather clears up. No screen power-up this morning until forced reset with power and next button. Cameras did not work until 3rd or 4th reset. I probably need to figure out a better mounting location for the camera control module I read somewhere during research that it and the APIM don't like to be oriented in weird ways. Originally it was mounted vertically and I moved it to horizontal to get everything to fit, but that is a long shot I think its something to do with failure to power up on start.
Still raining here but after more research I really do believe it is best to have the APIM and the Camera modules in their normal positions, both mounted vertically and back of APIM facing front of vehicle like infotainments mounting system. None of my GPS NAV stuff works right even in carplay it wanders all over the place. I'm sure part of that is not communicating with the TCU which I still have to debug and figure out why it's not working. But people that have been doing the sync 4 swaps on the maverics had lots of issues mounting the APIM horizontal like on the bracket they provide with this kit.
How hard will it be to mount the apim and tcu vertically?
Have to look at it when I get it apart. I think I can figure something out. TCU is on the back wall of truck behind single fold up seat. It is connected to antennas on roof and then all the way to front to the apim. I don’t know the name of the camera module but it sits directly behind sync3 screen on the airbox brackets.
Wonder if they are still working on this.
I've asked a few times and they dont give me an answer, but from what they told me it will run 2,500-3k if they do get it working correctly
Anyone checked to see if massage seats still work?
Update on my install, fabricobbled their bracket to get the APIM to mount vertically instead of horizontally. This solved my maps wandering issue. Chopped off the unused ACM Extension harness to clean things up a bit. ACM now doesn't have to be stretched as much and is just zip tied to that plastic crossbrace.
Still no backup cameras, just a black screen. Sometimes after driving for a bit a forced reset they come on. Messing around in forscan with them they can work but after everything powers down over night and I get in the truck the next morning they won't work.
Something might be wrong with my jumper harness, still not communicating with the TCU on the back wall of the truck, if I swap back to sync3 it shows up.
Had fordpass for like 2 startups, no nothing.
As above post, massage seat menu comes up but I can't select any of the options
I’m thinking about just keeping the screen I have now, not sure I wanna go through all the back and forth. Sucks, I finally have all my items for the install.
View attachment 198899View attachment 198900
Anyone else having this issue that mounted theirs flat?
Someone posted a decent install video.
@bbrett and @esw004 did either of you have to trim any of the plastic during your install?
No trimming, but I will do what he did on the trailer brake controller if I can get all the little bugs I have left worked out. Waiting on a new APIM from them, the one they sent me isn't working properly and has a broken housing in the back where you seat the main harness.
He trimmed it because he has the F-150 bezel without knowing he has the wrong part. You don't need to trim if you have the correct left trim piece.
Was wondering why my CarPlay Maps and Nav was off, thats because of the orientation of the APIM?
