Featured
- #61
- Aug 15, 2021
- 513
- 1,009
- 2022 Ford F350 Lariat 6.7L UP BAP Tremor and 2022 Ford F350 Lariat 7.3L UP BAP Tremor
- 2015 Jeep Wrangler JKU Rubicon Hard Rock - Tank
Awesome!!! I really appreciate the input and info. Of course with everything on my truck this can’t just be straight forward and easy haha. I have a question though. For my set up this is a set up that does not stay permanent in the truck. The fridge and other accessories only get put in when I go on camping trips which is every once in a while. I also have a EcoFlow delta max that I bring with me and keep those devices plugged into the EcoFlow and then the EcoFlow is plugged into the truck. So with that being said is the issue of my truck batteries not really reaching a full charge still a concern? Or would the on board chargers work for short camping trips like that where the camp site has power available and I plug my truck in over night or for a few days while at the site? Sorry I’m not very knowledgeable yet when it comes to power systems. I’m still trying to learn.
These are well thought out questions! The EcoFlow is a great way to run things for short periods, (short is relative to load requirements and time away from an AC source) and as long as you have AC at the campsite, easy to keep charged up for occasional jaunts in the wilderness. (Solar backup would be good here as well, though expensive, and need much more time for charging.) Having the truck as a backup charging network for the EcoFlow will still have the same battery discharge conditions. In other words, if you run the EcoFlow down to where it relies on the truck batteries to recharge or run, it would still drain the battery. Charging them back up with the Noco (or any other charger) must equal the demand.
Power demand is straight forward, you need more power to create less power. Essentially, no matter what means you use to transfer power, batteries, AC, BU generator, etc., it will require more power to maintain each device in the string. (Solar is the exception, this just needs time as the medium)
If it was me setting this up, I would use a battery tender type device (AC or Solar) on the truck batteries to maintain the charge, but I would be using the EcoFlow as my primary power source. I would have it plugged into AC (if available) or solar if the power demand is low enough to keep my accessories running and have enough capacity to maintain the charge on the EcoFlow. The truck is a good backup if none of the other devices are not available, but I would occasionally start the truck and recharge everything.
Current demand can be calculated that whatever your accessory needs are, you need that much energy plus the energy to run the generation function. Every time there is a "transfer" of energy, it requires that much more energy for the transfer function to work, as well as the load. (AC to DC, DC to AC, or DC to DC.)
This is an excellent thread and good timing for me to obtain more information regarding this subject. I'm not knowledgeable but in the process of learning. Have not heard of the Eco Flow...so, plan to read up on those units.
Recently purchased this fridge / freezer -------->
Elements Weatherproof Fridge Freezer | ARB 4x4 Accessories
The stainless steel Elements weatherproof fridge freezer by ARB 4x4 Accessories.
ARB has a power pack with a 15Ah Lithium battery for up to 18 hours of run time. The power pack is listed with the Zero fridge / freezer, but works with all ARB untis.
Have been looking at variety of products to maintain the current dual MotorCraft...and future Odyssey Extreme or XS Power batteries in my truck.....different products from Battery Tenders and NOCO. The truck also has the engine block heater.
It is my understanding the best way to maintain and extend the life of automotive batteries is to use a low 1.5 to 2 amp trickle charger about every 30 to 45 days...even when the battery is new and healthy. The high amp chargers....10 to 25 amps can be used to reduce the charge time. At present, I am leaning towards installing the NOCO 2 Genius 2D and NOCO GCP2.
NOCO GENIUS2D 12V 2A Smart Onboard Battery Charger For Cars, Trucks, SUVs, RVs & Lawn Mowers – Automatic Charger, Maintainer, Trickle Charger
The NOCO GENIUS2D is a direct-mount 12V 2A onboard battery charger, maintainer, trickle charger, and desulfator for lead-acid batteries, including automotive, marine, and deep-cycle types such as flooded, gel, AGM, SLA, VRLA, and maintenance-free. Designed for under-the-hood use and compatible...
NOCO AC Port Plug With Dual 18in Extension Cord
The GCP2 is an AC Port Plug with dual integrated extension cables (18-inch) that offers optimal flexibility and ease of installation. It can mount to the exterior of any vehicle to make the charging port more accessible. Equipped with heavy duty 14 AWG wire to supply power to your device, GCP2...
I have considered a third battery...a lithium to power the ARB Elements fridge and other small appliances when out and about away from the cabin. In addition, I am checking out products from the following two companies.
1. REDARC -----------> https://www.redarcelectronics.com/us/power
I talked to the REDARC regional representative a few weeks ago and he was very knowledgeable and helpful.
REDARC has some awesome products. Definitely like the idea of having a battery isolator on the truck. Dual Batteries pose additional concerns in regards to connection, charging, one battery draining the other, etc. Both batteries should be identical and always purchased new in pairs.
2. Jackery -----> https://www.jackery.com/pages/solar-generator-3000-pro-event
Not sure if I will splurge and get the Solar Generator 3000 Pro, but if so, I need to squeeze the trigger very soon...to save $399.00.
Jackery has a page explaining the connection of solar panels...in a series or in parallel .....and the advantages and disadvantages of each.
Ultimate Guide to Solar Panels in Series vs. Parallel
There are two options for connecting numerous solar panels in a system: series and parallel. This blog aims to explain why wire solar panels are in series or parallel, compare their differences, pros, and cons, and discuss which connection is the most beneficial to use based on your circumstances.
www.jackery.com
In short, I like the idea of using an on-board trickle charger to maintain the dual batteries and keep the power source...batteries, inverters, solar, etc. for the fridge and other small appliances, tools, etc. separate. So much information to gather...everyone has different and or unique needs. Hope what I posted above is beneficial to some guys.
Thanks to Brown2922 for starting the thread and all the great comments from everyone. Big ^High Five^ to Canyon Trekker for all of his input and knowledge.
