Both of the You Tube videos are close to target, but many YouTube explanations do not include the reasons "why" you hook up batteries and chargers in the manner described. There is a science behind this, and they don't go into the finite detail. This is important to understand when trying to determine if you need one or dual bank chargers for the truck.
I'll give the short version of an answer here:
Two batteries wired correctly in parallel will result in the exact same voltage when measured with no load, at either battery connection. The reason is because they are essentially equal to each other due to no current drawn by the load, (Truck in this case) and the wire size, which is never mentioned in the articles above, which is an important factor here, which I'll cover in a bit.
The batteries in the truck are indeed in a parallel configuration and the reason they both charge with the alternator at the same time while running. (Two alternators, if you have that configuration, do the same thing.) The batteries do not have, nor do they need independent chargers when hooked up in a parallel configuration and same age, in good condition.
Longer explanation:
As one of the videos above mentioned, it is important for both batteries to be the approximate same age (and style) due to deterioration over time, even though one battery can fail before the other. If only one battery goes bad, several things can happen. One battery may charge normal and the other may never come to full charge, whereby the charging system (alternator or external charger) can work very hard trying to equalize the batteries, which can over time result in one of the batteries overheating and evaporating water, the charger can overheat and break down, one battery will remain low, and you will lose starting "total" current, and possibly throw codes related to the batteries or even "false" unrelated codes due to a low voltage drop at the computer. Several other possible issues related to the starting sequence. This is why you always test the batteries unhooked so they are not in parallel. One good battery can mask the bad one.
In a starting situation, where the starter draws a LOT of current, if one of the wires of the batteries was loose or bad, or one battery was bad, most of the current demand would come from one battery. The capacity may not be enough to start correctly. This is especially true in the 6.7.
To address the charger:
When these batteries are in the truck wired with the heavy gauge wire that is used, (4gauge or better) they will be equal to each other due to the ultra-low resistance of the connection, and you really only need one charger for both batteries. Trickle charging or maintenance charge as I call it, is not a demanding operation. The NoCo video above is closest to the correct manner to hook up the charger, but remember, the negative is also the chassis, and these connections are using heavy gauge wires, so electrically, they are at the same potential. You CAN hook up a dual bank charger, and you CAN run a separate wire to each battery plus and negative, but it is not necessary in this case due to the heavy wire and conduction between the two batteries, and the ultra-low demand from a trickle charger. But running a dual bank charger, doubles the charge capacity if that's important to you. If your batteries go dead often and you need to fully charge them, this may be a good option to have.
In the second video, the gentleman is talking about the dual charger "testing" the batteries independently in a parallel configuration. Sorry, this is not true for the situation he has. When you have the two banks wired together in this manner, the "testing" built into the computer in the charger can be fooled by the good (or bad) battery and falsely accept or keep charging the bad battery (and good battery). In other words, if one battery is defective and they are in parallel with a large gauge wire, (this is an important factor) the charger computer cannot distinguish which battery is causing the reading due to the low resistance of the parallel wiring.
In a boat, it can be a very different scenario depending on age of the batteries, wire length between the batteries, wire size, how much they have been drawn down via electronics and the trolling motor, and the manner of the hookup. In a boat with a greater than 12 volt trolling motor, the batteries will be in series and MUST have independent charge networks. If using a 12-volt trolling motor and two batteries are used in parallel to increase the overall capacity, you can use a two-bank charger, in parallel, and they will charge just fine. They will also charge with one charging bank so long as the connection between the two are heavy gauge wire. (Albeit slower) The most important thing to remember here is that in a boat, the battery draw needed to charge, will be much higher than the trickle charge in the truck, to maintain the batteries.
I too, have a boat with four batteries and a quad charger. This is a must for this situation. I have also experienced many of the described issues above due to faulty batteries, chargers, and wiring. Side note, I recently updated my boat charger with a newer model and found out I was recycling batteries much sooner than necessary due to the old charging technology.
I run a 2-amp NoCo charger for both batteries in the truck and it keeps the batteries charged up for days. (Probably longer, but I can't help it, I have to take it out once in a while,) I know my total draw from the accessories on board do not draw more than 2 amps and therefore, don't need a heavy charger to maintain them. And yes, my green light of the NoCo comes on after completing the maintenance charge and as soon as I open the door, it resets the charge cycle due to the instantaneous current draw but finishes the cycle in a matter of minutes. That's all I ask of it. just maintain the battery to full. I did recently test my batteries (disconnected and independently tested) and they are still both equal and have plenty of capacity after one plus year now.
Modern day chargers have sophisticated electronics in them and not like the old chargers that tend to overcharge batteries. They are great for this scenario for people that have their truck sit for days or weeks at a time without running.
I hope this helps, I tried to avoid all of the ohms law explanations.
