I have a disease. (Yet another Battery Powertool thread)
I KNEW IT!
Awesome, brother. I'm a knuckle dragging MEPS guy. We need torque in boat loads, and the ability to abuse stuff without it breaking.
We used to end up with a lot of cracked DeWallt drill handles when I worked for others with company issued tools.
DeWalt is ok... just ok.
The biggest problem I've had with Milwaukee drills is the factory drill chucks locking up under severe duty.
Quickly solved with a better quality replacement from Jacobs.
Link it up! I have similar issues with the chucks. I almost break the handles on the drills all of the time 😜🤣🤣
I bought the stubby impact about 2 weeks ago and it's awesome. Very powerful and about 1/3 the size of my full size Milwaukee 1/2" impact wrench...and a LOT lighter too! They had a BOGO free and the stubby and the 5aH battery were $249.
Yeah, I paid like $230 for the 3/8" stubby with a battery and charger a couple of weeks ago. I think I have like 5 12v chargers now, lol. This deal is much better.
You picked up two 3/8" stubbies for the price of one at HD?!
I just bought mine as well, would have wished this deal was around then. Bummer!
After real world testing of both the m12 vacuum, and the m18 packout style vacuum. DO NOT WASTE YOUR MONEY ON THE M12. While it is nice if you only need to vac up a small amount of stuff. The thing eats up batteries waaaay too fast and it gets clogged easy. I could deal with the clogging, it happens, but it is very difficult to release the hose in order to aid in clearing the clog.
The m18 on the other hand is very powerful and for my use case, an 8ah forge battery has lasted for three jobs and still has 3 bars left. Mind you I am just cleaning up around where I drill holes in the walls 5-7 runs, three stories, probably 10-12 3/4" holes through top and bottom plates, blocking, and beams, per run. The m12 takes up to two of the 5ah batteries per house
Do yourself a favor and swap all your batteries for the M18 18V 12.0 (ah) Red Lithium Forge HD.
They are not cheap but your tools will love you and you will thank me later.
I run one of their roto hammers and before these were even released (make sure they are the "cooling" ones with the slots on the bottom), I was using all type and sizes of batteries. I think they have the standard XC, then they released HO, then they presented their Forged series but when this 12.0 came out, it made all the difference in the world.
Before, my hammer would cut out; thought it was due to ambient heat (which very well could be, plus I'm ripping up pavement that's 140 degrees or drilling through concrete) and it would loose significant power as the battery would drain. With the 12.0, that tool is giving you all it has and doesn't skip a beat. They also seem to run forever. I seriously replaced 12 of the XC 5.0 for two 12 ah Forge HDs in simple terms. They do take a lot longer to charge but they also last 5x as much and they DO NOT get hot, unlike the other battery types.
Regardless of the tool, as long as its an M18, all it sees is the HD12.0 nowadays.
I used to rebuild the XCs when they would no longer charge, now they're just sitting in the drawer looking for a dumpster.
For anything else, the M12 is adequate.
I run forge 12s on all of my tools. I have an 8 that was part of a bogo. It works good for the vac and an impact driver. My one guy hates the 12s on anything other than the big hammer for ground rods. Says they're "too heavy" 🤣🤣🤣
He does have bad shoulders though 🤔🤣🤣
100% agree with this.
I thought the Forge batteries were super expensive and not worth until i bought some and ran them in my top handle.
I wont run any other battery but the forge in my top handle now. Incredible how much of a difference they are compared to the HOs.
Finally gave my M18 hatchet a proper workout and hot damn what a little monster. Felled five 15-20’ tall trees (mesquite, palo verde, acacia, etc.) and the hatchet made quick work of breaking them down to load onto the trailer. My 16” chainsaw did the heavy cuts but the hatchet is a total beast for anything under 3”. I can’t imagine clearing trees any other way.
