Fumoto oil pan drain valve
Texmudder just cut a gal milk jug leaving the handle portion on, unscrew the filter inside the jug and let that old filter drop right in the jug. This works Brother. ????
You sir are a frickin G-E-N-I-U-S.........that's one of the best and simplest ideas I've heard in a long time. I've been using a giant funnel for years and it's kind of a PITA to hold that, mess with the filter, etc....but a nice jug handle would certainly make things easier.
Necessity is the mother of invention. Thanks Borther! Just pass it forward is all I ask. ??????????
Only problem I see with the Fumoto is that some asshole could crawl under and open it in 10 seconds. If you were parked at a trailhead you might not notice although I guess 13 quarts would probably be pretty noticeable.
or anyone with an adjustable wrench could still do it
I can probably count on one hand the number of times that I've taken any one of the trucks I've had over my lifetime in to get the oil changed. That being said, I've never had a problem pulling the plug and draining the oil. One advantage with the plug is that it is magnetized, so it will attract small metal particles that are suspended in the oil that would otherwise accelerate engine wear if allowed to remain circulating in the engine. My concern is that I would lose that advantage by replacing the magnetized plug for the Fumoto oil pan drain valve. Am I overanalyzing this?
^^^ A valid point!
Another thought occurred to me regarding removal of the plug. Since it is magnetized with the intent to remove small metal particles suspended in the oil from circulating in the engine, could removal of that plug void your warranty?
Is your factory plug magnetized?
Mine is not...
@Willie what year is your Tremor?
Mine does not have the magnetized plug…still love the ease of the Fumoto. ??
For the 7.3, was the adaptor needed for the F106N where the pan plug is recessed? Did my first change this weekend and this would have been very handy. Mine was not magnetic either. 2021
Speaking of magnetized plugs... Couldn't you put a neodymium magnet on the bottom of the pan and accomplish the same thing? Harbor freight sells a 10 pk for $3. You could even stack two magnets since they're so small. Just pull them before draining the oil out.
I think the pan is aluminum on the 7.3. I thought of the same thing just using VHB tape to hold the magnet.
This has been a popular thread and has included both 6.7 and 7.3 discussions. I just wanted to let those with the 7.3 engine know that the drain plug is threaded metric, 12mm x 1.75. I was given some incorrect information regarding the drain plug size and order and drain valve in the wrong size. This is the valve I plan to install when the correct one arrives from Amazon. This will be a very clean install and does not have a lever like the other brand that could get caught on something on the trail. Just remove the dust cap, screw the 45 deg. fitting onto the drain fitting and the plunger opens as you tread it on and the oil drains nicely down the hose into your pan with no mess.
When you disconnect the valve closes before the fitting comes off. Wipe away any drip and put the dust cap back in place, up and out of the way on the pan.
https://www.amazon.com/gp/product/B01MT5H2RR/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
With the recess in the oil pan the 45 deg. fitting should make the process easy and clean.
That's pretty cool. I'm gonna check which size I need for my 5.0.
If by chance it's a 14mm x 1.5, I have one I'll sell you at a discount. Also for anyone interested, I believe the 6.7 diesel is that size as well.
Thanks for the offer. I did some digging and it looks like mine is the same size as yours.
From what I found, the 6.7 diesel is that other size.
I'm gonna crawl under my truck in a bit and see what the situation is down there and make a decision.
That Femco is pure genius! Way mo betta than the Fumoto.
Ya and it fits nicely up in the recess for the drain plug on the 7.3, out of the way of any harm yet very easy to get to. I like that the dust cap keeps the fitting perfectly clean between oil changes. If you have a jug that holds the full amount of oil you can put the hose in the jug as you tighten the fitting an literally not get a drop on the floor if you're good.
The only down side is you have loose parts to keep track of but that's not a problem for me. Just clean everything up and put in a zip lock bag in the under seat storage tray or oil change tote in the garage.
I decided to order the Fumoto drain valve and install it at my first oil change. It is advertised to have a 60% larger drain valve for faster oil changes. The 6.7 oil drain plug and filter location make oil changes pretty easy and straight forward. (pic). The clear tubing will make it a bit easier to fill waste oil container.
When traveling out west and pulling our TT it will just be a bit easier to change the oil, vs going to a dealer.??
Here a list of what I ordered in case anyone is interested-
Thanks Ford for such easy access..
Just a heads up for anybody ordering the Fumoto 106N drain valve, just received mine through Amazon - correct package, wrong part inside. Package was marked F106N (should be long nipple), but actual part inside looks more like the F106S (short nipple). Already submitted to return/have replaced - hopefully the next one that comes in is correct. Didn’t order in time for my 1st oil change, but plan to have it on hand when the 2nd rolls around.
