For those of you who don't trust that, I have a couple Mityvac 7201 units and they work for pretty much everything. Haven't removed a drain plug from any engine in years.
Clean and tidy:
Clean and tidy:
Yep, I never ever use the quick lubes for the very reason(s) you stated. And if I have to use a dealer and at some point, which I surely will I will be sure the oil tech knows what a Fumoto valve is.I was traveling a few years ago in my then new 17 F350, some where near BFE I believe, and needed an Oil Change. (the Light is on) The Ford dealer was going to be an all day wait. so .. I gathered the Filter and Motor Oil and did the unthinkable. I went to Jiffy Lube. (father, please forgive for my sins .. again) I arrive, I'm well greeted, we talk a moment and am assured they change Oil in these trucks every day etc etc .. The get busy under the hood, they began pouring the Oil in, when the Girl under my Truck comes out, walk up to me and says that my Drain Plug is stripped. Because its leaking and wont come out. I explained no, that was the Fumoto Valve I asked you guys about. The one you guys said you were familiar with. She argues saying, NO .. Thats some kind of Plug because my Threads are Stripped and I'm expecting them to be responsible .. It gets worst. Then, all of them begin accusing me of lying to them. I'm trying to rip them off .. It get worst again .. Fuming mad .. (understatement) .. I have my truck towed out, to Ford. They gave me the Oil Change for free, just for the story.
ThanksIf your talking about the Fumoto valve website, they do have a valve listed for the 7.3 here is the link-
View attachment 15880For Ford 2020 F-250 7.3L V8
The powerful shopping cart software for web stores and e-commerce enabled stores is based on PHP5 with SQL database with highly configurable implementation based on templateswww.fumotooildrainvalve.com
Thanks! Never heard of these till this forum, like 3/4 of the other things I have bought for my tremor hahaSure, once I do my first oil change I will post a pic. Decided to wait until I hit 5k and a little warmer day. If you look at your oil pan drain port post#1, the valve will not stick down at all. It threads in and sticks straight back. ??
Dude you just saved me a lot of hassle. I ordered the same one two days ago, and I just called and had it switched to the correct one. Just in time because she said the slip had been sent to get pulled today. When (not if) we meet somewhere down the road, I owe you a beer or a stiff drink. You are the man! ????Heads up gents, I went to install the Fumoto F137N valve today and it was the wrong size thread, to small. I contacted Fumoto and they said it was a mistake on their website and they are mailing me the proper thread size valve. Do not order the F137N.
This is the proper valve/thread-
Glad you caught it on time Bro. Hey thanks for the cold brew offer, it’s all good!Dude you just saved me a lot of hassle. I ordered the same one two days ago, and I just called and had it switched to the correct one. Just in time because she said the slip had been sent to get pulled today. When (not if) we meet somewhere down the road, I owe you a beer or a stiff drink. You are the man! ????
Thanks for putting this out, I have one sitting here that just arrived, guess I need to make a phone call.Glad you caught it on time Bro. Hey thanks for the cold brew offer, it’s all good!
?????? I sent a PM to @Warpath so he knows the correct valve # as well. Trying to just get the word out and lookout for each other. ????
Dam...sorry Globalhawk, well at least you did not find out like I did after draining my oil. I went ahead with the oil/filter change and just reinstalled the OEM plug until I receive the correct Fumoto valve. I called a few hours ago and I already have a tracking number and the correct 14mm valve on the way. ??Thanks for putting this out, I have one sitting here that just arrived, guess I need to make a phone call.
I am going to use the clear tubing to drain oil into my catch can. I considered the right angle, but did not want it hanging down below the pan. Also the oil will flow straight out with the 106N and not be impeded by the right angle. Really just Personal preference. Are you using the right angle valve?I would recommend the one with the right angle on it. That way the oil goes down and not out.
No worries, the oil change is still a bit away, thanks to you, I have time to get it exchanged.Dam...sorry Globalhawk, well at least you did not find out like I did after draining my oil. I went ahead with the oil/filter change and just reinstalled the OEM plug until I receive the correct Fumoto valve. I called a few hours ago and I already have a tracking number and the correct 14mm valve on the way. ??
Anytime for a Tremor and USAF Brother to boot! ????????No worries, the oil change is still a bit away, thanks to you, I have time to get it exchanged.
Always use Ford or do it myself. And go USAFA! My son is a junior at the academy. Plays LacrosseYep, I never ever use the quick lubes for the very reason(s) you stated. And if I have to use a dealer and at some point, which I surely will I will be sure the oil tech knows what a Fumoto valve is. If the tech gives me a deer in the headlight look, I am at the wrong dealer.
Glad it worked out for you Brother, but it surely sucks what you went through.
Only one thing worse than a young kid with little to zero experience changing oil, one that thinks he knows it all.
Go Air Force!????????
Good to know @texmudder! ???? Awesome!I have had both on my super duties. The right angle never hung below the pan. I had the right angle on my 17 and the straight on the 14. When I finally order one for my 21, it will be the right angle one. I still use a bit of tubing to make it a clean dump into a bottle. With the right angle on there i can just put the bottle down and not worry about any side pressure produced by the hose. As far as anything "impeding" the flow the right angle will not affect the flow at all.
That is very cool! He will do well! ????????Always use Ford or do it myself. And go USAFA! My son is a junior at the academy. Plays Lacrosse
