Fuel Range
I don't think fuel pumps appreciate being ran to dry, reserve is there for a reason.
didn't say do it more than just once to see what your reserve really is.
i hate the zero miles to empty isn't accurate.
guess there's a reason for reserve
for folks that don't understand when is says you will be out of gas?
you will be out of gas.
glad you have a reserve
even though you don't know & don't wanna know what that reserve is?????🤷🏻‍♂️
  • Haha
Reactions: DFS
The reserve is set to 4 gallons by Ford. That published info is good enough for me to approximate if I feel lucky - hint, I don't.
If you are willing to use Forscan you can set the reserve to 0. That presumably is as accurate as you will get.
  • Like
Reactions: DFS
1,355 is the highest I've seen:
I set mine to 9 gallons when I went to the bigger tank...figured that would give at least 50/60 miles to get back to town for gas even if I had to use 4wd for most of that to get to hardtop.
the fuel tank size is too small on super duty's. an f150 supercrew has a 36 gallon tank and a short bed supercrew super duty has a 34 gallon. who thought that was a good idea?
Oh they thought about it.. Ford was just to lazy/cheap to get a bigger tank DOT approved in all 50 states...I had to wait a little over a year for TS to bring the 58 gas gallon to market...Thanks a lot California.
Filled up this morning and had 370 DTE. During the warmer months I get 400-430 with normal driving and stock tank.
I also added an aux 43 gal tank so not towing I can get 850-900 miles with normal driving. I think I've gotten around 1000 a handful of times. But typically only use the aux tank for towing on cross countries. Let's me go 400-500 miles between fill ups to get to fuel stations that fit the truck and 34' trailer more easily.
I always assumed the payload numbers they were shooting for played into it, but that was just a guess.
I might have had my truck 24 hours before the 60 gallon S&B tank went on. I can get north of 1,000 miles if I can keep it to 70ish on the highway. Witness one Houston hurricane evacuation shit show and you will not want to be the guy running out of fuel.
Houston shit show? I thought that was the preservation of the half-demolished and condemned Astrodome. Historic? LOL!
I have the smaller TItan tank in my '21, had it installed by the dealer before I took delivery.
It's nice not having to worry about stopping for fuel on trips and I typically fill up at the commercial pumps so it's quick to fill.
It isn't the maintenance cost as much as the $13,000 increase in the price of the truck. I can buy an assload of gas with $13 grand at $2.40 a gallon.
I live out west and haven't seen $2.40 gas since I was a kid, and I'm 72.
That said, aside from absolutely loving diesel performance and corresponding versatility, I wouldn't want to spend that much time in life looking for gas stations, and then standing there pumping gas... every 300 miles. Diesel is the best choice, despite it's overly exaggerated maintenance costs 👌
Rocking 60gal S&B here and it's programmed at 60gallons. Ain't no reserve if you wait till you are 10 miles DTE you'll likely put 59-60gallons into it. Def running on vapor and like the half gallon held inside the primary fuel filter.
I am looking to get the TF 58 gallon installed next month. Do you mind sharing where you got yours installed? I am in GA and wouldn't mind the SC drive for an installer that has done it before.
I had to go the Charlotte....PM me if your still up for it. :ROFLMAO:
You were able to reinstall the skid plate correct?
No that cheap sheet of Chinese pot metal went to the dump along with the plastic tank, the fact you call it skid plate makes me laugh...
You don't need a skid plate with the TF flow tank..Only damage to my tank has been to the coating from ATF when the tranny shit the bed and puked all over the bottom of my truck in it.
It will drag in 16" of snow so you can be tracked.
When my aleet pops up for 50 miles left and refill, it always seems i can put in 30-31 gallons
450ish, for in town driving on stock size tank so roughly 14mpg (7.3 gas) freeway gets me between 16-17mpg. With road trips and the 58 transfer flow tank over 900. I hand calc to see how much the computer lies....it does, a lot.
Your getting 17mpg on the hwy in a 7.3 Tremor?
Most of my driving is highway so maybe I’ll see a little better. Really looking at that transfer flow tank although dang thats a lot. The similar S&B is a fraction of the cost but im trying to avoid diesel.
Highway I get about 396-411 cruising 75 I average 15.2
