Fuel Range
Your getting 17mpg on the hwy in a 7.3 Tremor?
Drat I meant to say non-tremor with 3.55's my bad everyone, my bad. I've kept everything stock and run door jamb tire pressures too.
I wonder what mileage difference would be with a more highway-oriented, lighter tire vs the stock Duratrac tire. Same size, of course.
Both mine show 430-460 at fill and I average 14.5 on my 3.73 geared 7.3. I averaged 14.1 on the Tremor driving it back from TN for 300 miles.
My best tank has been 14.14 mpg and my average overall is 10.3 in almost 20k miles. Towing is 25-30% of that.
Houston shit show? I thought that was the preservation of the half-demolished and condemned Astrodome. Historic? LOL!
As a native Houstonian, I voted to demo that dumpster fire.
A lot of distracting side comments on this thread. If you’re getting a Tremor, you’re DTE gauge will read somewhere between 300-400 miles, depending on how you drive and whether unloaded or towing.
I drove my ‘21 7.3 Tremor 45k miles on the stock tank and the DTE varies considerably depending.
Regarding the TF tank. It’s a game changer in multiple ways and definitely worth the price if you travel extensively. As far as the stock skid plate, it’s worthless for actually protecting the OEM tank, let alone the TF tank, which btw is three times heavier steel than the silly skid plate you are removing. Edit: BTW it will not fit the TF tank. Picture for size/shape comparison:
With the TF tank on a 23 or newer truck, you’ll lose an accurate DTE reading, but your fuel gauge will read accurately except for an increased reserve of about eight gallons. To me this is a minor issue that likely will have a solution eventually.
Now disregard all the irrelevant banter from the diesel guys, and go ahead and get that 7.3 Tremor you know you want. 🍻😎
Thanks for that review.
Most of my driving is all highway. I was hoping the fuel range, on average, would be closer to 400, not 300. Ive gotten used to my Tremor F150’s 580-600 range. Color me spoiled.
The email has been sent to Granger and waiting for their reply/request for the deposit.
All highway you will definitely get around 400. It's the city driving in the hills that will lower it for you.
It’s Florida. We have no hills. The landfill is the highest elevation in Florida.
I’ll be up ion your neck of the woods in March. Got some friends that live in the Mount Pleasant area. I’ll keep an eye out for ya.
When we decided to upgrade trucks, It was easy for me to accept the lower mileage of a 350 Tremor for a couple reasons. First we were moving into retirement and a new camper and boondocking was definitely a lifestyle we were embarking upon. Also my former 2005 F150 5.4L Lariat got around 16 mpg average when new, but with 280k miles on the clock was now averaging 12-13 mpg, so the Tremor would be a net gain considering capabilities.
With the 7.3 engine in a Tremor you’re relegated to the 4:30 gears and heavier tires and that nudges the average mileage slightly lower. If you’re willing to forego the Tremor package you gain options, but the gain is minimal. And if you’re the type that would opt for aftermarket wheels and larger tires, you’ll be back to Tremor mileage anyway. The 3:73 gears will only gain 1-1.5 mpg average depending on how you drive, but only with highway tires.
Grainger is good to work with, so if for some reason there is a delay of more than a couple days for them to respond, send a followup message. They can be busy but they are normally very responsive and helpful. Good luck with your choice and the process!👍
Mine typically reads about 390 MTE in my normal mixed daily use. Will drop by ~100 miles when I'm towing and FWIW I did have significant range anxiety on our 10k mile road trip from Delaware up thru the rockies from Grand Teton to Jasper, AB however I never was in a situation where I was running low on fuel without a good spot for gas even up in the more remote parts of AB and BC we went thru.
After that trip I have ruled out getting the larger TF tank. That $4k price basically paid for my 98 Mustang.
When you fill up, on average, what is the range the computer displays?
I have a 2024 with 4:30 rear end and a stick tank. When full it shows around 350 miles. I am abrading around 11.5 mpg pretty much every where, from in town to highway. It drops to 9.5 when towing.
The best I’ve seen with my 2024 KR 7.3L based on highway travel is 480-mi DTE with avg MPV running a little over 17. I have to drive very ‘thoughtfully’ to get that mileage. 😉
Typical around town mileage is 12-to-13+ mpg, so a fill-up shows 320-to-360 DTE.
J_Man
The biggest issue when towing, I've found, is just having to plan fuel stops for the gasser. Not quite as easy as a diesel or using big-rig lanes. If you're able to plan the fuel stops ahead of time, it's not as bad. If you're able to get an end pump, you're usually golden.
