Front license plate with winch
My take on a couple ideas from this thread. Rubberized magnets on back of original plate holder. Cut off top “hooks” and put magnets that suck to bumper..
Good work on that. It is simple, puts the license plate in a good position, and requires little in the way of fabrication.
  • Like
Reactions: ccw
Great Idea! It appears to be a Ford bracket. Do you have that part number?
It appears to screw in on the underside of the bumper? Am I correct?
It is the stock bracket that came with the truck. Not sure of part number. On the bottom It clips into the valance and the top I have it held with magnets.
Thank you! I don't need PN then as I should see this with the truck. I didn't realize that the stock bracket was on a hinge. Great Job!
Not on a hinge…. Just plastic so I kinda pushed it out of the way in the picture. 😊
So the question would be - how to access the winch easily.
Push two plastic clips on the bottom of plate bracket pull out. Then pull magnets off bumper. Of in 15 seconds or less.
Thanx!
K.I.S.S. - "Keep It Simple, Stupid"
Do you have a link to the magnets you've used? Thanx!
But..,no drilling and easy on and off.
Just installed this today and it's somewhat easy on/off. Obviously doesn't leave any sign that it was present, but I wouldn't want to install or uninstall it without a ratcheting wrench with a bendable head. Couldn't get a socket and ratchet to fit in the limited height above or below the tow hook.
Also, the bolts holding the license plate to the mount have an Allen key head rather than Phillips or a hex head. Not the end of the world, but also less common for license plates.
No question it's built well - the aluminum is all super thick - I just wouldn't classify it as "easy" on and off. Simple, sure, but a bit of a PITA.
My install post with a picture: https://www.fordtremor.com/threads/project-shadowfax.6005/post-148883
Yep - understood. I was going off of the instructions and the fact that there is no drilling involved. Thanks!
  • Like
Reactions: ccw
I’ve scoured the web for a front license plate solution compatible with the factory Warn winch and didn’t like any I found so I came up with my my own solution. I bought a Peterbilt hinged license plate holder and designed a bracket to mount it over the winch. The plate holder should protect the winch from dead bugs and road grime, and lifts out of the way when you want to use the winch. Hopefully it works out for me.
  • IMG_1270.MOV
    17.8 MB
I made this bracket. It's laser cut 304 stainless. It mounts with magnets to the winch. What do you guys think ?
