Front license plate with winch
This is exactly what I need to do! Hopefully Home Depot has some flat bar in stock. What size are the bolts?
I used what I had laying around the license plate mounted to the bracket has two quarter-inch bolts with ny- lock nuts the bracket mounted to the underside of the truck is 5/16 the bracket is stiff enough that the one bolt on the underside is all that was needed no drilling holes in bumper
It’s done son! After hours of applying pressure with my fingers and the help of a clamp. I got the front license plate holder on! I feel more accomplished than the valedictorian at a gynecologist graduation!
Just got my plates the other day. I'm still debating, but leaning toward running without the front plate. Front plates take a beating and look like crap. I've been pulled over for no front plate, but it was back when I was a youngster that looked like a troublemaker because I was. There's enough obvious trash running around here to keep the Sheriff's Dept busy full time. I don't have anything to hide these days, so I think I'm gonna chance it.
Is that the performance part mentioned early in this post? No drill? is that why is was soo hard to attach?
My winch was ordered with the truck and installed by the dealer. Ford has been sending the wrong front plate holder with the trucks that have a winch. So, a few of us ordered a Ford plate holder that will work with the winch.
The installation is straight forward: Loosen the two acorn nuts on the winch fairlead, slide the new plate holder between the fairlead and the winch frame, tighten the acorn nuts back up.
My issue was loosening the two acorn nuts. The bolt head is behind the fairlead and would just spin with the acorn nut. I used an impact drill like others have posted but it did not help. Maybe the acorn nut and bolt are a little rusty? I'm not sure? Anyway, I found that vise clamp at Home Depot and used it to put pressure on the bolt head. It was a slow process but it did work. I was able to loosen the acorn nuts, install the front plate holder and tighten the acorn nuts back up.
The installation is straight forward: Loosen the two acorn nuts on the winch fairlead, slide the new plater holder between the fairlead and the winch frame, tighten the acorn nuts back up.
Thank you!
Interesting thread. My Tremor was delivered with the wrong plate bracket also. Dealer just shrugged his shoulders and said he did not have a good option. I'm in northern California. I've ran most of my cars without front plates, and have not been pulled over for it in 30 years, but this truck gets a lot of commercial use and I just feel better not giving a DOT guy a reason to pull me over to have a chat. Options as I see them: 1) no plate - probably a fine solution for most. 2) Mount off to the side by the tow hook. - I don't like the asymmetrical look. 3) Flipster. This is awesome in most ways, but the exposed hinge mounted by drilling through my painted bumper isn't awesome. 4) Factory Ford proper winch mount bracket. I like this, but the plate hangs pretty low for my liking. 5) Custom - This is what I did. I took the non-winch plastic bracket and riveted it to a small metal bracket that I made and then inserted rare-earth magnets. This can be removed in 15 seconds with no tools. It is centered, it isn't too low and it takes maybe 30 minutes to build, drill, rivet etc.
Nice work! How do you get the magnets to stay in place in both the steel and plastic brackets?
The metal bracket is riveted to the plastic. The magnets just sit in the 5/8" holes pretty snugly and since the metal they sit into is 1/8" thick and the slot they fit into is barely more than that, the magnets have no choice but to stay in the holes. I was going to epoxy them, but there is no need. I should add that the magnets are 5/8" diameter x 1/8" thick. The metal is 1 1/2" by 1/8" flat bar. Rivets are 3/16" with the larger head to not pull through the plastic.
I decided to build a flip-up plate holder. I've ordered custom plates so might as well mount the front too. Mounted with thread inserts in the bumper. It's spring loaded, with a v-notch barrel it holds in up or down position. I still have to paint it...
I like you solution the best; you should probably make some and sell them. I'd buy one. BTW, the DOT guys don't need a reason to have a chat; they can stop you for inspection any time. ;)
I like your solution the best; you should probably make some and sell them. I'd buy one. BTW, the DOT guys don't need a reason to have a chat; they can stop you for inspection any time. ;)
Thanks. It is a simple solution and easy to fab up. Too busy with real work on my end to venture into making them for others. And you are right about the DOT guys, although they are pretty easy to get along with where we are.
