Front license plate with winch
Picked up my truck from Granger on Friday. I expected to have to find a plate bracket but when I arrived the winch and the Ford factory plate bracket were installed. I didn’t think to ask if they ordered the bracket.
Less about the plate, but more on the install job - do you have a pic? I've seen horror stories here of dealer winch installs gone bad. With so many ordering from Granger I'm curious to see the job they do.
I’ll have to take a pick. Didn’t spend a lot of time inspecting the installation. It was a bit chilly out.
I think I would make the new ones out of 14ga instead on 10ga. No need for it to be super thick.
Are you making these plate holders? Running a ultra hook so just need to make sure it has enough stand off to clear it. Happy to pay for it and shipping.
I used this Peterbilt hinged plate I found on Amazon and built a simple bracket to hold it in place. The plate lifts out of the way when I use the winch and the plate protects the winch from road grime and bugs. The plate does not make contact with the grill in the up position. These pictures are from three months ago and it is holding up well.
Why try to invent something when Ford makes a license bracket to use with the winch - (LC3Z-17A385-BA)? It has been mentioned on the forums several times.
I cannot figure out how to get that one to fit! It is sitting in the garage waiting. ;)
Sawrfworks makes a license plate relocation bracket if you want to just have the plate moved over, although it uses the tow hook so you're down one hook.
I have decided to go naked. I will do something when it's inspection season.
I have been pulled over twice in MT for no front plate, wish i could go without it. Anyone hear from @Perplexer on the brackets? I am also in.
I have the winch with a factory front plate holder. Dealership gave me the new plate holder since I have a front plate that needs to be on mine.
Truck goes in next week for the winch, will ask what they recommend but not sure which way I want to go yet. I may go no front plate for a while, would not be the first time.
I have been running naked now since February, but now with the Factor55 UltraHook it's likely going to be more of a noticeable thing.
It’s just the license plate holder off of the dually. The part# LC3Z-17A385-BA.
It’s just the license plate holder off of the dually. The part# LC3Z-17A385-BA.View attachment 51189
Can you take a photos of what that looks like further away - dead on? I may consider this if my state gets all legal on me.
I live in a state that requires front and rear plates. I have the warn winch option which removes the license plate location. Does anyone have a known solution for this. Been googling but have not come across something I think will work. Very little room around the winch and it is recessed a little. Thanks,
Here is a link to the information for the Ford part you are supposed to get with the winch.
According to the Ford Performance page with the winch details, you need…
“Optional part : Front License Bracket LC3Z-17A385-BA in states/provinces requiring. See a Ford Dealer or www.FordParts.com for more information. A Factory Ordered Winch option does include the brackets in a vehicle prep kit.”
Looks like you can buy it online here:
Not sure if this is the right place to post this but I just had a long ordeal with my truck. Be carefull sucking the winch in all the way if you have adaptive cruise control. The fairlead plate also holds the sensor for the cruise control. And if you suck the winch in all the way the plate bends. This makes the sensor point in the wrong direction. Then it faults out and you have to take it to ford to fix it.
Hi guys. I am going make a couple of these brackets. I need to know who wants one.
What brackets? The one in the pictures in this post?
I made this bracket. It's laser cut 304 stainless. It mounts with magnets to the winch. What do you guys think ?
If so, I’m definitely interested! Though how much room is there to keep a hook sucked all way in? I feel like with the factory hook and isolator it wouldn’t fit.
Though perhaps that’s the reason to justify getting a Factor 55 setup. :p
