Featured
- #21
Are you talking in general or in the truck? What iphone do you have?Anyone know how I can find out if my iphone will do this wireless charging?
My wife and have both put the wireless charger in the rear view long ago. If I plug her iphone 11 into a wired charger from the truck it heats up quite a bit. Must be something with that gen phone...It works with my iPhone 11 Pro, but it also tends to heat the phone up pretty well.
They all do it to some degree. My iPhone 12 pro got warm using it and my 14 pro does it as well.My wife and have both put the wireless charger in the rear view long ago. If I plug her iphone 11 into a wired charger from the truck it heats up quite a bit. Must be something with that gen phone...
I don't know. I don't see any markings on it that says what model it is.Are you talking in general or in the truck? What iphone do you have?
I always have used wireless chargers for years at my office and home and have never ever had such significant heat to my phone as the ford charger. Most of my chargers barely get a little warm.They all do it to some degree. My iPhone 12 pro got warm using it and my 14 pro does it as well.
Wireless (inductive) charging produces heat. That, coupled with a car manufacturers putting them in a cubby hole with a general lack of air circulation and folks using wireless CarPlay at the same time and well, there ya go..
My 19 expedition had the same wireless charging cubby, my wife’s acura has the same design, a 23 Land Rover I drove recently had a similar pocket. All of them got hot while charging and using CarPlay compounded it.
Settings, general, about, look at model nameI don't know. I don't see any markings on it that says what model it is.
Nice find @MiTremor906 !!!Well for anyone that is interested in getting more space in this front tray and ditching the wireless charger. Although I may see if I can't find a spot that I like it better and relocate it but currently that is more of a dream than anything I'm working on or even planning. **Back on track**
I found this tray that I switched out today. Part number is KL3Z-1513594-AA. Says that it is for a 2018-2021 Expedition but it fits. It also lets you maintain both the USB and the USB-C and also the ambient light. Note both of these need to be transferred over, along with the sliding cover, from the current insert to the new one.
View attachment 113776View attachment 113777
Mission now is to locate the rubber insert for this tray. I believe it should be item 20 from below.
I've actually had it for a little while now but didn't want to post it until I knew it would fit. Life and then Michigan weather just made it take a little longer to test fit.Nice find @MiTremor906 !!!
Just wondering when you removed the wireless charging pad - can that power connection be re-used down there? Meaning, if I would not care about the wireless charging pad, but mount something different there - what does it look like?Well for anyone that is interested in getting more space in this front tray and ditching the wireless charger. Although I may see if I can't find a spot that I like it better and relocate it but currently that is more of a dream than anything I'm working on or even planning. **Back on track**
I didn't take pictures of the wire harness but can take some pictures of the charger connector tomorrow if you want. I will likely need to pull the center console again in the near future and can take some pictures of the harness then. Not sure what power it's getting or what you would be wanting to hook up but you likely could repurpose it.Just wondering when you removed the wireless charging pad - can that power connection be re-used down there? Meaning, if I would not care about the wireless charging pad, but mount something different there - what does it look like?
I find I spend as much or more time trying to get my phone situated in the tray and then removing it vs. just plugging it in... Android Auto really drains the battery so I would rather be wired anyway. My phone is older (3XL) and I dont have the heat issue, but maybe that is due to the new tensor chip in the 6/7 as you mentioned.I have a Pixel 6 Pro. It fits in the wireless charging cubby ok, but it is definitely a little awkward getting it out of there. I just tell myself that is a "feature" to discourage people from using their phone while driving.
When I'm navigating and playing Spotify with Wireless Android Auto, my phone will eventually overhead on the wireless charger and I have to plug it in, anyway. Recently, something got updated and improved the time-to-overheating from ~20 minutes to something more like 40+ minutes (I think it'll go longer if it's not working too hard). In general, though, even when my phone doesn't overheat on the wireless charging pad, it charges so slowly that it can barely keep up with the drain. When it finally starts to reach the overheating stage, it will lose power faster than it can recharge and then it will eventually disconnect from the wireless charger all together. I'm pretty sure the issue is with the phone and not the truck's charger because I've tried it out in the same circumstances using a different wireless charger that I keep on my nightstand at home and the same thing happens. I've also had the phone replaced with another one under warranty because I thought that the issue was due to something being wrong with my phone, but the replacement phone did the same thing.
I hypothesize that the Pixel 6 line is just underpowered processor-wise and generates too much heat when it's demand is high (such as navigating/streaming audio through Wireless Android Auto). That combined with the heat generation of wireless charging is too much for it to handle, so it deprioritizes the wireless charging and throttles back the process to reduce heat.
I usually only use the wireless charging pad during my morning/evening commutes and typically just plug in if driving any further than that.
-SR-
I think the location of the charging pad in our truck is intentional - away from steering and eye sight as you're driving to prevent the temptation of you grabbing or looking at it.
As opossed to other leading car brands who have it atop of the center console or alike.
Here are some pictures of the charger side of the connector and then just overall view of the backside and part number for anyone interested. I'll get pictures of the wire harness connector next time the center console gets pulled.Just wondering when you removed the wireless charging pad - can that power connection be re-used down there? Meaning, if I would not care about the wireless charging pad, but mount something different there - what does it look like?
Oh, very cool. Thank you. I appreciate it. Not what I had expected, but gotta do some research on this.Here are some pictures of the charger side of the connector and then just overall view of the backside and part number for anyone interested. I'll get pictures of the wire harness connector next time the center console gets pulled.
View attachment 113871View attachment 113872View attachment 113873View attachment 113874
If there is anything else you need or what, let me know. The charger is easily accessible at this point and I'll make a note of any pictures for next time.Oh, very cool. Thank you. I appreciate it. Not what I had expected, but gotta do some research on this.
Here is the wire side connector. It is molex part number 34791-5181.I'll get pictures of the wire harness connector next time the center console gets pulled.
