Front charging tray
The rubber mat insert has been found and been confirmed to hit. Part number JL3Z-15045G34-AA. Project is now complete.
So for the folks that have already done the swap, is there a video or can you explain how to replace the bin? I'm going from wireless charger to plain bin so I can add the ShawnTexan Switch-Pros mount and SP-9100 in that bin. Just don't know how to tackle getting it out.
Never mind. Found the video on the VHF thread.
I did this same swap and I am happy how it turned out. There are a bunch of YouTube videos on removing the center console. I followed the videos on removing the center console, but just slid console back a few inches to allow for tray removal. The tray door is held in by a couple of screws and the tray itself is held in my four screws.
interesting thread, I have a magnet mount for my Pixel 6Pro and just upgraded to a Carlinkit. I use the mag mount in both my personal truck and the work trucks so I can't use the wireless charger anyway bc of the metal plate. I might have to consider this conversion and clean that area up some for access badges and whatever else I want. Not sure if the WC would freakout with access badges laying down ontop/around that.
After reading the thread it is the best one after searching I've found for this question, but if there is a better thread please point me to it.
I just got an iphone 12 pro max and when placing in the wireless charging tray it immediately starts charging, but after a few minutes, maybe 5 or so and sometimes less, it will stop charging. I have the thinnest case possible and it starts charging immediately and doesn't shift in the tray. It does not even have a chance to get warm. Anyone else experiencing this issue?
If I shift the phone up and back down it starts charging again, but usually for not very long. I haven't done any long drives to see what happens.
The phone wireless charges just fine at home.
Also, for those not aware, there are some settings under 'Battery' on newer iphones that some of you will probably want to turn off. I've turned them both off. One is Optimized Battery Charging which is supposed to be the phone learns your daily charging routine blah blah blah. If I put my phone on a charger I want it to charge to 100%. Turned this setting off permanently.
The other setting is the Clean Energy Charging which will reduce your carbon footprint... That was all I needed to read before turning it off permanently.
I am having the same issue. I assumed it was because the phone shifted....maybe not. I have a 13 pro. I have gotten used to using the 12 volt changer connected in the center console.
I have a Pixel 6 Pro. It fits in the wireless charging cubby ok, but it is definitely a little awkward getting it out of there. I just tell myself that is a "feature" to discourage people from using their phone while driving.
When I'm navigating and playing Spotify with Wireless Android Auto, my phone will eventually overhead on the wireless charger and I have to plug it in, anyway. Recently, something got updated and improved the time-to-overheating from ~20 minutes to something more like 40+ minutes (I think it'll go longer if it's not working too hard). In general, though, even when my phone doesn't overheat on the wireless charging pad, it charges so slowly that it can barely keep up with the drain. When it finally starts to reach the overheating stage, it will lose power faster than it can recharge and then it will eventually disconnect from the wireless charger all together. I'm pretty sure the issue is with the phone and not the truck's charger because I've tried it out in the same circumstances using a different wireless charger that I keep on my nightstand at home and the same thing happens. I've also had the phone replaced with another one under warranty because I thought that the issue was due to something being wrong with my phone, but the replacement phone did the same thing.
I hypothesize that the Pixel 6 line is just underpowered processor-wise and generates too much heat when it's demand is high (such as navigating/streaming audio through Wireless Android Auto). That combined with the heat generation of wireless charging is too much for it to handle, so it deprioritizes the wireless charging and throttles back the process to reduce heat.
I usually only use the wireless charging pad during my morning/evening commutes and typically just plug in if driving any further than that.
-SR-
My Pixel 7 Pro does the same thing in the truck. Never got to the point of overheating but it definitely drains faster than it charges. I just turned of the wireless Android Auto connection and only use my phone plugged in for nav if the ford nav can't find something...which unfortunately, given the cost, seems to be quite often.
I've discovered a little bit of good news. If I put my phone on the wireless charging pad as far left as I can put it and put the top of the phone toward the driver side (left), it does not lose the wireless charge connection. I've put it in each time like that today and it has stayed charging each time. This is an iphone 12 pro max with a very thin (Spigen) case.
Has anyone else asked their dealer about the wireless charging issue? It shouldn't be this finicky. First world problems...
I finally gave up and got a MagSafe charger plugged into USB. It charges twice as fast, never loses connection, and doesn’t overheat my iPhone. It also clicks into place and if I want I can twist the phone to the angle I like.
If I have a guest in the truck they can use the crappy Ford one :)
Is that charger flat enough to lay on top of the built in one or do you put it in console next to the cupholders? Nice looking charger in case the ford one ends up not working well enough for me.
It might fit but it’s a really small space and I didn’t want some strange magnetic field interference to happen. I just put it in the cupholder console and have a short 6” USBC cable. Removing the OE one altogether is a good idea too.
Just as a follow up: I did find if I put my phone in one certain place it does not lose the wireless charging connection. For my iphone 12 max the phone is oriented with the top toward the driver situated so that I can just see the usb emblem. In this position it does not lose connection to the charger. Sad that it is so finicky, but at least it works.
Does anyone know if anyone makes a better charger for the OEM wireless charger location as an upgrade instead of a delete?
I did have a customer working with me to make an adapter to move his iPhone up in the wireless charger but I haven't heard back:
Edit: I'm an idiot....I was the one that was supposed to be doing the testing! 😂
