- Jun 23, 2020
- 2,089
- 8,565
- 2020 6.7 F250 Super Duty Tremor Lariat Ultimate BAP
- 2022 KTM 500 EXC-F Six Days
I use the same rigging method for my rod as @TRAMPER , but I leave mine in one piece. The end place that the rod ends up in is with the reel sitting in the little indentation box in the middle of the dash, and the rod tip goes out the open sliding window in the middle of the rear.I had a question for you all - when you’re out fishing and going between spots, how do you transport your rods? My son and I were just taking apart the middle section and “folding” it in half so it fit in the back seat, but I really didn’t like this. I want to have some kind of way to take it fully assembled and ready to go for the next spot. Just curious what most of you guys were doing
Now there are two methods of getting it there. My brother in law opens the back door and hands the rod to himself reel first through the open slider and then pushes/lifts the reel forward to the dash hole. The method I use leaves all doors closed, the mirrors folded out, and a front window down. Then I stand up by the hood and can place the rod through the gap in the mirror mount, tight to the inside of the head rest, and out the back slider. Then I either hold the rod as I open the door or I put it on the console before I open the door. Then I place it in the dash hole. I usually put a hand towel or something like that on the dash. You can fit up to four rigged rods in that way. Just put two each on either side of the middle back headrest. You can also roll up a towel and place it along the top if the back seats to work as a cushion for the rods if you are worried about bouncing while going fast on rough terrain. If you’re going slow short distances or over smooth terrain. They ride fine on the glass in the back.
I hope that makes sense. It’s super easy and quick once you get the hang of it.
