dull thumping sound
Starting to hear some thunking noises here, Plus a bad squeak at times. Now to decide if I am going to let the dealer try to fix it (time plus wait for parts) or just drop $400 on some 5100s.
I just started hearing a clunking noise as well. I pushed the bumper up and down and could hear the rear left shock making the noise and Im sure the right shock is soon to follow. Im not thrilled to have to spend 400 or more for shocks that Im not supposed to need already and certainly dont want to sit and wait at a dealer for them to change them and only to have more "bad batch" shocks installed on my truck and then to have to deal with this again down the road. Actually what I would like is for them to give me the shocks so I can change them myself instead of waiting hours at a dealership.
It's never ending with this nonsense.
Ford really produced a product with never ending hassle for the consumer whether its through warranty or out-of-pocket repairs.
I am on my 4th episode of the infamous thump, clunk, thunk coming from the front and as always - the driver front.
I am full PMF up front.
I am on my second set of ICON shocks (which are again all shot, by the way). The first set went out with 2K on them :sick:
I am just fresh out of alignment #7
Truck drives mint, straight like an arrow; super tight up front - but its this subtle dull thumping noise that just keeps find a way to come back.
I'm leaning towards shocks this time.
2022 F350 TREMOR with 26K on the clock with 4.5" ICON Stage 1 on 35s
Ordered June '21
Shipped Sept '21
Picked up Oct '21
What about the body bushings to frame possible coming loose or prematurely wearing ?
So, service department is going to take a look at it tomorrow. Service writer says they have been replacing a lot of F-150 and SD spring packs. :confused:
I have some more thuds going on in the back of the cab - but I have not located it yet.
Well, just got back from the dealer. They couldn't replicate the squeaking that I am hearing but are going to order new rear shocks due to the boots hitting the body on both. :confused:
Of course, when I get home and pull into the driveway, big squeak. :mad:
3 to 5 days on getting the new Ford shocks. I am also getting a set of 5100s from another member. So, will have options.
The ol’ rule out game. 😒
Alrighty then - not a huge shocker - but I found my sound in the rear end - shocks are shot again. So first set was replaced at 500 miles, second set needs to be replaced now at 10,000 miles.
So what do I do gang - do I have Ford do another warranty job on these, or do I just replace them with something else. Pretty lame.
I am having Ford replace mine next week (they texted me today that they got them in). I am still buying a set of 5100s from another member. Figure I will be swapping them myself next year.
I am a big Bilstein fan from my BMW days - so I likely will opt for a set. Anything would be better than the freaking shock sound. Are you having issues with the front set too? I probably should replace those as well.
I replaced the defective OEM rears at 500 miles with Bilstein 5100’s. Fronts never made a sound but will likely swap them out shortly anyway.
Such a disappointment these OEM shocks are. I guess I may as well swap them all out too.
Hi guys, I just joined! Love this forum been lurking for awhile.
Anywho, I have experienced this clunking and I am on my second set of factory “Premium” Tremor shocks. Apparently according to the proud engineers and the Ford hotline this noise is considered a normal characteristic for the Tremor Off Road package and does not impede safety so no repairs are required.
I talked with Ford Canada and first they told me to trade it in lol. After a few heated conversations the best they could do was warranty the rears with the same garbage.
I’ve been a Ford Diesel guy since 96 and it was a little heartbreaking to get that kind of answer. There really should be a recall.
Instead of putting those tremor shocks on again the Service Advisor I had been working with is going to give me a bit of a deal on some aftermarket shocks on all 4 corners and a front leveling kit.
Does anyone know a good M/T tire that offers a nicer ride than the Duratracs?
Thanks!
JR
Thanks!
JR
Check this section out. Many have been running tires other than the the stocks - so far I have been pretty happy with OEM.
Where are you all finding the best deals on the 5100s?
Wow just found this thread by accident, really wasnt even looking but mine started making this same noise recently, almost every time I back into my driveway. Def feels/sounds like it is from the front.
My thump did not change or go away with replacement 5100 shocks. Going to remove rear sway bar next, to eliminate that possibility.
Well that sucks to hear. Mine went away the first time - for 9000 miles. Did you add a sway bar?
Yeah. It’s a Hellwig. I just got home from a camping trip. I don’t notice any handling issues at all pulling my 10k pound 5th wheel. The noise is just an annoyance at this time.
