You must be the anomaly, lol. There is always one.My 2013 f350 6.7 has the original Rancho shocks. A little surface rust but fully operational. 11 years old and 114k miles.
sameI put Bilsteins all around my Tremor and the sound went away. After reading the forms I didn’t see any point in having the same crappy shocks put back on over and over again.
So I have been getting a loud pop on bumps, the truck has had more sway than normal and has been riding really ruff. My driver rear shock had no rebound, the passenger rear would slowly rebound but made a loud bubbling sound (probably internal oil leak). The front passenger side shock had no rebound and the driver side shock was exhaled to compress, but with no rebound. These shocks made it 50k and they were completely shot. I installed new 5100’s, ride is much better, no popping sound. Install took me 1.5 hours, but I’m very particular, I put ant seize on all bolts and torqued them to spec.Same. My rears were full of air pockets. My front passenger side would not rebound at all and seemed to have metal on metal grinding. Wild how this could happen so quickly.
Good move, your shocks were probably gone long before 50K!!So I have been getting a loud pop on bumps, the truck has had more sway than normal and has been riding really ruff. My driver rear shock had no rebound, the passenger rear would slowly rebound but made a loud bubbling sound (probably internal oil leak). The front passenger side shock had no rebound and the driver side shock was exhaled to compress, but with no rebound. These shocks made it 50k and they were completely shot. I installed new 5100’s, ride is much better, no popping sound. Install took me 1.5 hours, but I’m very particular, I put ant seize on all bolts and torqued them to spec.
Same noise on my 22 tremor too, happened at 30k miles. Terrible. I replaced my shocks with the Bilsteins as well. It helped the ride, but not the thump. Ford replaced my sway bar and tie rod ends and claimed it fixed it. It did not. Sadly, I’m trading this truck in because of this issue. I paid too much money for this thing to literally clunk down the road, waiting for something to break.2022 F-350 Tremor. At 4800 miles fronts started knocking the rears shortly after. At first, I thought it was a rear spring shackle or spring stack and even the shock mount bushings. The rear knocking noise. You could hear by lightly pushing down on the rear bumper. You can also hear the noise on a slow rolling on small bumps like a dirt road. You hear a lot of discussions on here that is the shock mount angle, and all that jazz,blah blah blah. I actually disconnected the rear shocks myself, and the noise went away, hooked him. Back up in the noise came back. From what I understand the tremor shock has a dual valving system of some type. Noise is a lot worse when it’s cold out. I finally convinced the dealership to change the shocks. The noise went away for about three or 4000 miles and then came back. I heard of some guys getting Ford to cover a set of Bilstein 5100’s. My dealership told me to go pack sand. Tremor, shocks are junk.
Have you checked the spare tire cradle? If the tension is too loose it will rock back and forth and clunk around.I have a 21 platty tremor with 11K miles on it now. The truck runs and drives great, no complaints with it except that it has developed a dull thumping sound under the truck in the last couple thousand miles. I only notice it at low speeds while driving over bumps. I think its in the front end but the truck seems to transmit sounds through the frame so its hard to pinpoint exactly where the noise is coming from. I don't hear it at higher speeds but I think it's there but masked by road noise. The dealership did a quick look at the truck (whatever that's worth) at the last oil change and said everything looks good to them in the front end. Anyone else have any experience with this or know where I should look first?
You will enjoy the improvement.Yeah, I ordered the 5100’s. Should be here today.
