dull thumping sound
I had a thump and it wound up being a broken shock.
'22 350 Tremor with Carli Backcountry 5.5" and I have the same noise...drives me nuts...only hear it at low speeds also...but may not hear it due to road noise at higher speeds
Fox’s are blown already. I’m hearing more and more from people to stay away from fox right now. I remember when I ordered the steering stabilizer last year. It came already blown with fluid everywhere in the box. Probably one of the reasons why Carli dropped them
Well, as stated before, I replaced all four factory shocks about a week ago. Local suspension shop put on Fox 2.0.
Here’s the fun part: the golf-ball-in-a-bucket noise is still there in the rear end. So I’m my case, it wasn’t the shocks. They even checked the spare tire, etc. when they did the work to make sure something wasn’t loose. So when I pull out of the garage and turn (it’s a side entry) and the back end starts to flex at low speed, there it is. Every time. I’ve crawled underneath while my neighbor walks around in the bed or pushes up and down on the bumper and for the life of me I can’t tell where it’s coming from. But it’s not that loud when doing that. Definitely louder when driving. Of course, truck drives fine and it’s really just an annoying thing, I suppose. Also as mentioned before, truck is all stock (minus the shocks now).
At least it rides better now, though. That was a nice surprise as I didn’t really expect to feel much change in the seat-of-pants. I just wanted the noise gone. But these have made a noticeable difference (not huge, but definitely different in a good way).
I’m taking it back to off road outfitter as they offered to put it on the lift and check it all out for me since the dealer already said they couldn’t find anything wrong. Will update later if they find something unique that hasn’t been discussed so far.
Looking forward to your findings. I've also had this "golf ball" (great description by the way) sound since I bought it a year ago. I haven't changed the shocks because the timing of the sounds, don't correlate to the shock activity rolling down a perfectly flat street. My shocks are not blown as in many cases, they do have a lot of pressure when removed and compressed, no oil seepage, and don't seem to have any rattle when slightly tapped or jostled. I didn't want to buy new shocks if they are not making the noise. Yet... (Maybe down the road a bit.) I've always believed this could be shocks but hasn't been pressing enough to lose the truck for a week to be looked at by the manufacturer.
Incidentally, I've found so many sources of rattles and cured many. with either silicone, rubber sleeves for squeaks and rattles on the brake line, or removal of "excess debris" left over from the build. (Screws, plastic pieces, etc.)
When (if) it ever stops raining here, I may take the shocks out and drive without them to see if the rattle is still there. The truck is obviously still in warranty, but I do like analyzing these things myself for the confidence factor.
I do have the undeniable "clunk" when bouncing the rear end, but it's not the same pitch and frequency as the rattle. The clunk is not prevalent while rolling, the rattle is.
Just wanted to add this info for the group. I had the dull clunking at low speeds. Replaced shocks with Bilstein 5100's. Better ride, but clunking was still there.
It was warm today, so I started pulling things off one at a time to use the process of elimination. Right shock, left shock, spare tire, etc. I found the culprit. The Hellwig sway bar that I installed last year. I detached the links, and the clunk was gone. I put the links back on, and re-torqued all the hardware. Everything is as it should be now. Nice, firm, compliant, and quiet. Not sure what exact part was causing the clunk. I'm just happy that it's gone.
2700 miles and I’m getting it as well, not convinced it’s a shock and only curious because I don’t know. Love the truck
I pulled my Fox shocks (from Carli) and dont think they are the issue....re-torqued all the carli suspension bits and still have...worst part is I cant seem to have anybody else hear it!
I just dropped my truck off this morning for the same noise at low speeds. I was an ASE-certified master heavy equipment mechanic for twenty-five years and I couldn't figure it out. I also have an annoying sound coming right above my head in the headliner that sounds like peeling Velcro. 11009 miles on a 2022 truck. I hope they get this resolved.
I had this exact same noise and you description of it is spot on. My daughter sat in the back seat and isolated it to the back corner of the sunroof. After cycling the sun roof a few times the noise immediately stopped and has not returned. That was a few months ago.
So what's the easiest test for the shock thump noise? disconnect shocks and drive? I'm getting the dull thump at low speed so afraid it might be time to replace.
Thanks. Good thing to check for those with a sunroof. My problem is I don’t have the sunroof. ARGH! But even this morning, that clunk was alive and well. :) I haven’t had it back on the lift again, but hope to soon and maybe check leaf springs, etc. So far it’s a mystery.
I have a 21 platty tremor with 11K miles on it now. The truck runs and drives great, no complaints with it except that it has developed a dull thumping sound under the truck in the last couple thousand miles. I only notice it at low speeds while driving over bumps. I think its in the front end but the truck seems to transmit sounds through the frame so its hard to pinpoint exactly where the noise is coming from. I don't hear it at higher speeds but I think it's there but masked by road noise. The dealership did a quick look at the truck (whatever that's worth) at the last oil change and said everything looks good to them in the front end. Anyone else have any experience with this or know where I should look first?
I am having the same issue, also caauaong an intermittent vibration issue. Just yesterday I climbed around the rear of my truck, and found the rear calipers to be loose! The mounting bolts are tight, as I tried to tighten them. Anybody else check this issue?
On my truck, I could simply push down on the rear bumper over and over to make the rear end of the truck bounce. Not only could you hear the thumping when doing that, my dad also put his hand on the shock at the same time and could feel it.
-SR-
I just got my truck back from the dealer. Left front shock (inner shock failure) they replaced the shock and fixed the rattle in the headliner. yay
@DrSpeed had a great explanation for this in another thread, which I'll quote here:
It makes sense the Kings would have significant compression damping both because of the softer springs that Carli employs and the fact the Pintop in particular is designed for high speed off-road use. In high speed the suspension will see big hits that need more compression damping beyond what the springs can provide.
learn something every time I come on here, makes sense.
  • Like
Reactions: ccw
My dealer has told me it was the rear hitch. I left it there for the first oil change at 3K (sooner than needed, but whatever) and the trailer module recall. They didn't remove the hitch because it was locked with my locking pin. I will remove it and bring it back when I have time, but I will be pretty embarrassed if they are right.
I thought mine was the hitch, it wasn't
@BoilerRealm I had the same issue with the Hellwig - tech support told me that some of their bars went out with holes that required a 1/2 inch (instead of 7/16) bolt at all 4 link connections - they sent me the new bolts and I installed (PIA) and the issue is gone. Note that I quieted the bar down by re-tightening the original 7/16 bolts but that was a temporary fix. So if your clunk returns contact Hellwig for new parts.
Hi I have the same issue in my 22 350 tremor. I installed a 1.5” level kit at 6200 miles and now at 9k miles dealer telling me it’s the kit and the 5 components wore out in 3k miles of very, very light driving. And of course won’t fix under warranty as they say the level is causing the issue. I know it’s the pre death wobble issue as I have had 4 of these trucks. Ford wants 2 grand to replace “a rod” and spacers. So frustrating. I can’t talk shop talk with them and Seriously need help to get my brand new truck fixed. Any suggestions???
Little bit off topic, but I have noticed a rattle when driving at low speeds over rough terrain. I believe it is the parking brake cable rattling inside the guide sleeves. This sounds like what you fixed, but I'm curious what your solution was?
