dull thumping sound
My fan clutch started @ 6000 miles, drove it until 12,000 miles and they replaces fan clutch which FIXED the problem. I now have almost 23,000 miles and no issues yet from fan clutch.
New shocks coming, could have been back to dealer next week, but that doesn’t work with my schedule, so going in on the 27th to get them installed.
I have a 21 platty tremor with 11K miles on it now. The truck runs and drives great, no complaints with it except that it has developed a dull thumping sound under the truck in the last couple thousand miles. I only notice it at low speeds while driving over bumps. I think its in the front end but the truck seems to transmit sounds through the frame so its hard to pinpoint exactly where the noise is coming from. I don't hear it at higher speeds but I think it's there but masked by road noise. The dealership did a quick look at the truck (whatever that's worth) at the last oil change and said everything looks good to them in the front end. Anyone else have any experience with this or know where I should look first?
Tremor shocks are garbage and capable of making this described sound when they go bad. Mine went bad at 7500 miles, many others on here have had them fail with less. I could duplicate it by bouncing suspension with truck off . Check the shocks
Ford must have gotten a different supplier for the Tremor shocks, don't see to many 2020 on this list, if any in reference to shocks. I have had no problems with my OEM shocks and ride quality with my Tremor. It still amazes me on how well it rides for a heavy duty truck solid axle truck.
I'm in the class with @Grabber, I have 48,000 miles on my 2021 and my shocks are still performing great even though they has suffered some severe off very rocky road abuse.
Went in for an oil change and the rear clunking. The dealer didn't bat an eye and ordered a new set of shocks. Of course they are backordered and will take 2-3 weeks to come in. The good news is they are going to do the APIM update at the same time so that's a plus. I hope Ford got wind of the issue and has made some design improvements so they don't have to keep replacing them but that would be wishful thinking...
What is the APIM update… mines going in to dealer Monday.
It seems like every single 2021 and 2022 had the rear shocks go bad… would really be incredible if they are still using the same supplier. Get it together Ford
So I have the same clunking noise on my MY22 that has been pretty common on this forum and have diagnosed it as blown rear shocks. I am about to have all new shocks installed on Monday of next week.
Back at the dealer getting the new shocks. According to the service rep they're still the same as what came on my '22, so I'll be back in 4k - 6k miles or so. Since it takes so long to get an appointment, I may just make one now for late May. :cautious:
Edit - two new shocks plus a new driver side battery. That’s some serious failure at this mileage.
I wouldn’t call it serious. Fords shocks are inherently terrible and I’ve had them go bad on every ford truck ive owned in the past 10 years.
I have the same clunk like a golf ball in a bucked sound…will see what the dealer does for it.
Where they belong
Same here. Everything else on the truck is great, but that noise and thankfully, this forum helped me identify it. I even had the service department look into about a month ago when they did the recall stuff. They said they “tested” the shocks and they were fine. Funny, for about two days I didn’t hear anything, then it went right back to the low speed clunk. In the garage, I can push down on either side and reproduce it easily. But I’m just biting the bullet and having aftermarket shocks put on this Friday.
So last week while having the 10,000 mile service done at the dealer, I told them about the shocks. The service manager drove the truck and then tried to tell me that "It's a super duty, it's normal". I then jumped up and down in the bed and he could hear the sound from the outside of the truck. He crawled under and put his hand on both shocks and could hear and feel them "clunking". He said that it was part of the break in process, and that another set of shocks would do the same thing in a few thousand miles because it was the same design/part number. He then told me that there was another older tremor on the lot, and it did it much worse than mine. His logic was to live with it.
On an unrelated note, the same service department did not grease the u-joints on the front axle. The service advisors (several of them) swore to me that they were not greaseable. When I brought them outside to my truck to prove to them that there were indeed zerk fittings, their story changed and they tried to tell me that actually the tech must have greased them because of the grease they were able to wipe away. (it was old, crusty, and covered with road grime from the initial application in the factory 10,000 miles ago - clearly not fresh).
Overall, not a great experience. I went home and immediately started shopping around for some bilstein's and got out my grease gun.
Slight redemption though... customer relations called me a day later to see how my service experience was. At that point, I explained the entire ordeal. To their credit, they are now ordering me new shocks and said they will service the front end. They are offering me a loaner vehicle too. Somewhat optimistic at this point that it will be taken care of. In the future however, unless it's a serious warranty issue, I'll be doing all maintenance in my driveway.
Well, I did the fronts yesterday... 26k miles.
Driver front gave up the ghost at some point apparently, and would not extend on its own. Basically just compressed on it's own and fell out lol.
JTMfKOs8vfVgRg_n_MCHWixElOX7MZ8VrC_UZpnqGt7m_JOupLc9f1ykHR60u-QrHIXrf9n10xfkxBURTGU6MHev2Ypo7cz_Qj_u50KiTmB3rAwtmLetF8UKEOlkuLPt6c4mKfMuAaUvC0gOcInwW33DhAXIUlD0svI_yWQ31X5oPxgK0sfwMaJXKzf-dsxp_OPkSkOVr4_CjGlDQQ9KJ-Bg2q6oEUVomQci8F1iyCar3eHvPG9zBqjbYZBPbt6VXQFziui_koa18fYr6KYjax4JSbUI9L6O6exU2U_x_6onfrYi3ggBEt-NZOStcds5fzAtjoZXGj4wNCv78v3AFgXXkRb38ihYcxjOFFweNm696kfsVLp2MDPKzk5WDZr1VvPqp9Ttjl3TeYkosyqbWMHPaNZPREDagOQna0Rru9v8bCnjgjuj42zzFgt_f1C4dfj5Yjj5-LhcPVRG8U5d9TzwT5p3z4E-A3o_S2pNAxHqSStH0_uktXmqmv2J4s3fKr1p0NWT8-WRfpcU2lG6K9PNJVCYzOiJcguffJJeL_DMygXnw1LqFc9nzzotMatqx6A6anqWTMbT7z1mZiC6wwKDttXubgiM7Pz1RYlcic3bifNR9K-kKNHoaNJMX8TJFxmECAm5Ph5zmL-wOgsfpuxBmlLp0drYHVa1xt8XznjqspOaqQLvNJLaVhFdZ5D5MmiFwlSrLyF5Qo22tskQL2Hxf7UU823nZ6rEMMBmte8zxYR4LENPEbYeXI3Jce3YvAsm6lpWda92Zb3yA-KfDcO3FWduNC3TCDaHQaReGK_dOHta_PQ5J4n7fh7A0UySrsj7tK0SleqlwHbSdZyyJvZnrkLbw3y6Mm8EfLMVI8kN4Pjg-1YU7jSg2_f_JYf_BZZrCoEPBuxg70lTFMoZIKqdXSOs6jHstCV0JLJVSBwAZ5zHwA=w246-h437-no
zEcabgOy7x1PsEEMoM1CFh4IWiC-3sLtdSKStWD3Kzi5Hcl-UemBVu78LmEvjGLvqxw9NA8gfp8yKwirXyJ0jXcOxxFGb1wwf0oCRqzomYkgZjnu7v_Ld0mIwjB1ZP-11o8e54sCjG9y9eUsBAloiK6XDYoqN7mOJYQ-B3MDn7EBJQkzzVbVd0NU4I1P3CPxIezMFWRlarbJFTV3m0UFJI84tBH72V5nJ0GxuZOON9yvzXEIMfgwTwDDAiX45rGvQXFdXDET7zMQnd8y_lB2hTRUaMgnQmgegAiQFIaBhgoPZ_lR-x85LhsqnFrGANeNX84HHg1Ut8HTOmCmcwA2in2270-9bvQIrECeAydg_rID2tIdPdEif-CAF5MDCWYd3WiSqgyZWzNNJn_pmuJQRusgnkzWqIJx4phT4FgHDwTImGiFyPa0igBJmH-Fnw-7W7gIcPM3QUh8lyr0KRqEzPEHmMq81iC2jo03_WfSnyUSf_zglnM6DnZhxW_mG0QeXWRyR7ieDmCgTMOzWLn_Y65wncYuHv7enLmDQhXITq67UM4Zhma4JAwcKjDuJ2TOkJfKBvnVCYZsJAh5y52sdY9LwTqgJ18g6DJHCzi99Q0QOcp0FJlvzkW5-uwiA_aM5fHmIzfaBr8ADki2US6Qdltk5NA1WwxCLjsTXLtzLYv9JwiQMkdyRRtr5cCRnZ3x1isfQKRNrwYIWCnjYxvFyW0Kcu38A4dyCAwwYPz8LGkEsbNIjl4Dbw7XZWrYpjYlceP3nnGa5IaOf7PlD5XGp90y0x9Pi7xmZkjCgvUPS6zpAJzw198zV5wN_nIEicmD05LtlWr6OtgedCyAIDAHbdPwIsw3MLSF_1JLU3bUqln_nz8bS0x-JeEt4_n_UHeFzZED6-zePzPuINwoo2PpcuMgy3SpRyrNrhgabFvkv1FdxTTftQ=w328-h437-no
R9KnQsYR2nsPXcVwBz96LLoUNjlxP9EiFK2rNdS1SbnrWRCvb3On2iVAOGyt9zzaN3Evt7agA9j_g5dw_QXlrWkeWZ8yNplgfHKqcnkKl8bEdtL2v26nwW8lB46I-_bEBQbtgFywIKeAO401WdB83J45ZheprndnZ3veVV4mse1Wh9VrcqVjEkNIjbGv7DGLHlAqL8pEDHEckQtyTN2aupa-Jsm8ojmL3m6IY8ibqxgFqzWncqtk6hrK6oRglc6sw_dBf4rT3hRsSf-20upJi6AGrocWkraU8PXZN1b2hWOj1gHhFyEbkgnZzk8ZiORVOpf4FGwfuV4N1d9ybPsihQweGGP0l9Wukx-xTlIubI1QppbXU_b_aQUNrePMOUyxesNSUJJthHPXqRVaa9ONE8fKtD3_eFBlt_csPegxFhTqdV8z17uOBlA6ljGksfGKGW51U55KR1MqKzQUdEqXLrk1zjgLpaHX3E0LkcL_cBYrUOekkAy-17ewxrM_kOI5NxOWuTW94MBE2ED4TvsXk8ykBpypXyD5q_HBZhycHDqgOCj4NNhI4uqp6WmJ8XmqofhMln9wowVI8x5T0Okhy3R3VGWTXH1C18X_vh_JiDi0TIkupx5d4rLb35E6R3GcP6GM1W6zwcdVrIZvy_nTuoVN_ZrHnvCc5mbVJZIEBOXWbmOl5OFyDiScB5wvRtS-TlXLjJZGfqebOGvxaWBd5lavH5Yf5t_jXbnQaHdNb6oa2M9ixO2VXU-OKDmi3CyHTds-VL99WPmldv8XbjTX8QoMzdZLuTR-Z7M7GdCgr4ORDKwGzzcJC_ZJb9FLTOUuLe-zzyY1bTrz6J-8e4Hgo_9S6EfImtemGHkUYX-2DGCu-6Tv5NWeveTJOqBF5vLmsVM799F7X4vAxn0mfw4WO-ga22r1igo32exISLQKHvzRZJTwgQ=w727-h969-no
I get a slight thud on a u-turn that I have to do pretty much any time I come home. I assumed it was the tires rubbing or smacking the edge of my mudflaps. There's a high probability I'm not adding anything useful to this conversation, lol
Those look sweet! I may go this route the next time the factory shocks give up again. Let us know how you like them.
Keep us posted on how you like those bilsteins !
already a huge improvement over the blown factory stuff, the ride is greatly improved from what I remember with the factory shocks. Bridge approach slabs are just absorbed and the truck does not nose dive as hard under aggressive braking situations. I've always wanted the external reservoir shocks even though I probably will never use them to their full capacity. I don't remember the truck riding this nice when it was new. I have always been a fan of Bilstein though, I ran the 5100s on my Excursion.
