Driver door rattle.
Hopefully this will help someone. Depending on weather, I would get a typewriter noise in my driver door over might bumps in the road. This would happen at low and high speeds. Drove me absolutely nuts.
I did the following trying to fix it:
  • Removed door panel about 5 times...padded everything in sight
  • Adjusted the door striker in and out....not the issue
  • Tightened the door hinge mounts to the body
Nothing worked. Finally, I noticed the door sheet metal itself would make a popping noise when opening the door on occasion. The noise was coming from the lower door hinge area. Did a ton of forum searching on Ford Trucks forum and saw a guy mention that his door was "soda canning" and making a typewriter noise. He made a small dent next to the lower hinge on the door itself - basically strengthening the sheet metal in that spot. I did the same (without making any kind of visible damage) and have gone almost 60 days and 2,500 miles with no typewriter noise anymore!! Confident I've found the fix for my issue. Good luck everyone.
pics please. mine is doing this exact typewriter tick
See below. I used a 3/8 extension and a hammer. Wrapped the end of the extension with a piece of vinyl I had laying around the garage to avoid scratching the paint. I put two dents at the locations shown via red arrows. Only took about 2 wacks per location. The dents are not visible to anyone other than me but can be felt by hand. Hope this helps:
Hope this works for you. At first, I was hesitant that it was the solution as everything else I did was pointless. But, at this point, its clear to me this is the fix.
I was wondering where the red arrows were but now I see. I might do this just in case
This is potentially great. Just to confirm, is this a remedy for the popping/creaking I get when moving the door in/out? The sound like something is crunching? It’s a detail that bothers me every day.
I had that popping crunching noise, but what really bothered me was the typewriter noise it caused when going over bumps, it caused the door to “soda can” and making this tapping noise. YMMV
So I just bought a 22 and started having this issue, I took off the door panel and inspected everything inside and jiggled everything, no sound! But when I slightly moved the door back and fourth it replicates this sound, gonna lube the hinges and see if that works
I assume you know where the sound is coming from but I recently got a rattle in my truck and it was the friggin passenger belt receiver tapping the center console 🤣🤣🤣 yours doesn't sound exactly like it but, when you figure this one out, that'll be your next annoyance... 🤣
Bro lmao, yeah I narrowed it down to the driver side door somewhere! After lubricant was added to the bottom inside door hinge, so far it has disappeared! We will see for sure in a few hours
Read my posts. Exact same problem. I thought tightening hinges and or lubricating would work…nope
I'm going to try this tomorrow, my door does it as well and it's driving me nuts.
My truck has destroyed 3 sets of door latches (idk how, but the plastic rips off them after a few months of contact to the striker). Thought maybe that was the reason my door creaks, but nope.
So, @boisefly & @Alpine_otlw .... it's been a few weeks, any updates? Rattle still gone?
Mine's done this on and off since new, but had disappeared for awhile..... It's back today though with a vengeance, so going your route if it's still working.....
Oh yes! Update!..
k, so I did what boisefly showed and I'd say the rattle is nearly gone! Not completely because I think I didn't either put those dents close enough to the lower hinge or not hard enough hits (did 2 at each location). I also ordered some sticky felt strips and put them behind the door panel and is was squeaking and super annoying.
I will be doing it again once I get my truck back tomorrow (getting my Carli kit installed).
Overall, I would definitely recommend doing this if you're hearing your door rattle.
Over 3,500 miles and some very long road trips….zero typewriter noise since!! I just did a 6 hour drive yesterday across Idaho. It’s a stretch I do often. In the past, my door would rattle so bad I would start punching it out of frustration. This is the solution for that specific typewriter noise…if that’s what you have
Oh yes! Update!..
Gotta give that lower hinge area some real solid wacks. Should be able to feel the dents with your hands and see them when looking close. The dents are not really visible in my pictures posted previously.
I have used felt pads on my old 150. Worked great. Cheap and they come in so many sizes. My 22 250 with 22000 miles on it sounds like rocks are in the doors going over bumps. I do that the passenger door squeak like in the video posted. Almost sounds like the plastics are too loose. I have put felt between the plastic and steel door before and that has worked. Get the same color and no one will notice.
has anyone installed surgical tubing inside the door weather stripping? is it even possible on these new trucks? i believe it was possible and done on on previous years.
Yes it’s still possible as the part number on the cab weatherstripping is the same. (Did this on my truck)
