Driver door rattle.
Gotcha. Bummer
I don’t remember where I read it but there was a theory from someone experiencing the same issue. He asked if my door made a clicking type noise as I opened and closed it. It did and still does. His door did as well and he felt it possibly involved the area where the door hinges are bolted to the frame. Who knows.
I’ve read the exact same. Heard it’s the lower door hinge from what I’ve read on other forums. I actually just loosened my hinges this morning and tightened them down hard. Going to see what happens over the next couple weeks.
Sounds good. Will be following. If it works will do same.
So after tightetning the lower door hinges a week ago, I have experienced zero rattle. Typically, the rattle would show up 2-3 times a week. I'm not holding my breath yet but if I make it a month with no noise, I'm going to be excited.
Well, jinxed myself. Rattle was back this morning. Might just remove my drivers door and run the truck without it
Lol. I'm sorry to hear that. I was on a camping trip and got pretty excited when I saw your initial post regarding the hinge tightening worked.
Could be totally unrelated but both front doors were making ticking sounds this morning until I got a car wash and then both were completely silent.
Drives me crazy. Really can’t find a rhyme or reason. Doesn’t seem to be temperature related. Just comes and goes randomly.
Same. Nothing seems to be consistant or a specific cause
My '24 has had a few noises coming from the drivers side door since about 200 miles. One was fairly easy and it was the chrome trim on the door cards squeaking against the window/door lock controls. I carefully slipped some felt tape between the chrome and the control and it went away. The most annoying one came from the top corner and sounded like a rattle/creak. Tried a few methods including adjusting the door striker, adding tubing inside the body weather stripping, and adding electrical tape to the striker with little success. What worked was just lubricating the outer seal at the top of the door with gummi pflege, which if you have ever had a German car you would know about. A light coat of weatherstripping grease can also do the trick.
I thought for the longest time it was the big door/body seal and no amount of lubricant would quiet it down until I put it on the topmost strip. For mine, if you stood outside and pushed the top corner of the window frame in, you could make it make a creaking sound. It seems like the doors press against the body seal somewhat loose from the factory and you can feel them moving around as you drive if you put your finger between the top door frame and body seal. Moving the striker inwards to make it seal tighter or adding tubing to stiffen the seal makes the doors not move as much and does help a little, but I didn't like that I had to slam the door to close. Opening the door made a pop sound that I felt shouldn't be good long term so I readjusted the striker to how it was from the factory and pulled the tubing out of the door seal. It's been 300 miles and everything is still quiet.
I've done just about everything youve mentioned. Ours is a tapping/clicking sound inside the door - its almost a metal on metal/mechanical tapping. Sounds different from yours...conundrum. That said, thanks for the feedback.
My creak sounded like a ticking sound but it sounded like it was coming from above my left shoulder. If you play music with some bass in it, do you get any rattles coming from the door? If you haven't already, I would pull the door card off and take a look inside and probably cover every contact point between plastic and metal with felt tape. Also, make sure to lubricate the door seals under the seal on the door side, not just where it contacts the body.
No, just from road bumps. Its within the door panel. I have removed the panel about 6 times and padded every single damn thing...some say its the hinges, some say its the lock rods, some say the striker. I've messed with it all...I say its a god damn mystery
Still have the typewriter sound in my drivers door. Exactly as shown in the video in the first post of this thread. Still nobody solved this if they had it?
Mine is the drivers door and its the thud thud thud when hitting hard bumps(dirt road or interstate) where if you have your hand on the door you can tell it is the full weight of the door banging against the latch. Seems like the hinges have the door sitting just a tiny bit too low, and when you hit a bump it lifts the door and then drops all of its weight back onto the latch. Not 100% of the weight is on the hinges, some of it is sitting virtically down on the latch. I've had it to the dealer twice. They replaced the latch this last time, and it did nothing...
frustrating
reviving this thread. mine just started doing this. any fix?
i vaguely remember something about it actually being the door check?? 🤷🏻‍♂️
that seemed to be where the rattle was coming from this morning
Ive also got some noise in the front A pillar area, I believe. I'm not sure what it is or specifically where and it seems to be something new. I wonder id it's something due to heat warping.
Hopefully this will help someone. Depending on weather, I would get a typewriter noise in my driver door over might bumps in the road. This would happen at low and high speeds. Drove me absolutely nuts.
I did the following trying to fix it:
  • Removed door panel about 5 times...padded everything in sight
  • Adjusted the door striker in and out....not the issue
  • Tightened the door hinge mounts to the body
Nothing worked. Finally, I noticed the door sheet metal itself would make a popping noise when opening the door on occasion. The noise was coming from the lower door hinge area. Did a ton of forum searching on Ford Trucks forum and saw a guy mention that his door was "soda canning" and making a typewriter noise. He made a small dent next to the lower hinge on the door itself - basically strengthening the sheet metal in that spot. I did the same (without making any kind of visible damage) and have gone almost 60 days and 2,500 miles with no typewriter noise anymore!! Confident I've found the fix for my issue. Good luck everyone.
Any pictures?
