Driver door rattle.
any tips? what size tubing did you use?
Post #5 and 7
Hopefully this will help someone. Depending on weather, I would get a typewriter noise in my driver door over might bumps in the road. This would happen at low and high speeds. Drove me absolutely nuts.
I did the following trying to fix it:
  • Removed door panel about 5 times...padded everything in sight
  • Adjusted the door striker in and out....not the issue
  • Tightened the door hinge mounts to the body
Nothing worked. Finally, I noticed the door sheet metal itself would make a popping noise when opening the door on occasion. The noise was coming from the lower door hinge area. Did a ton of forum searching on Ford Trucks forum and saw a guy mention that his door was "soda canning" and making a typewriter noise. He made a small dent next to the lower hinge on the door itself - basically strengthening the sheet metal in that spot. I did the same (without making any kind of visible damage) and have gone almost 60 days and 2,500 miles with no typewriter noise anymore!! Confident I've found the fix for my issue. Good luck everyone.
Can you explain what the popping noise is? I have the typewriter noise that kinda comes and goes but is often. It’s on my driver rear door and it’s actually on the opposite side of the hinges but if I press down on the area it kinda makes that noise. I just want to verify before I put a dent in my door haha
Will reply to your DM
See below. I used a 3/8 extension and a hammer. Wrapped the end of the extension with a piece of vinyl I had laying around the garage to avoid scratching the paint. I put two dents at the locations shown via red arrows. Only took about 2 wacks per location. The dents are not visible to anyone other than me but can be felt by hand. Hope this helps:
Just wanted to extend my gratitude. Followed the same steps and haven’t had the typewriter sound return in almost 7k miles. Strange how such a minor change (eliminating that intermittent sound) has made me happier with my truck.
Gets me stoked to hear this. And totally agree, its a game changer!!
Hey Let Em Run,
I saw your post about solving the tin can/typewriter noise rattle coming from your driver's side door. I'm almost certain I'm having the exact same issue on my rear passenger door. I've experienced it as well on my driver's side, but it seems to have gone away, and now my driver's side just has some noises over big bumps that sounds like the door has to much play in the frame.
I wanted to see if you could help me out with some information on how you made your dents, how big the dents were, and how you decided where to place those dents. Did this end up solving your issue? Any information would be greatly appreciated. Thank you so much in advance. This noise is driving me insane lol
Hey Let Em Run,
The noise drove me aboslutely nuts as well. I tried everything to no avail, until making those dents. The noise has never come back. See post #63 of this thread where I added pictures. Need to be on a desktop to see the arrows.
Awesome to hear this was a legit fix. Just two main questions i have if you don't mind adding some insight.
1. How did you decide where to make the dents? Do you have a different thread you found on this aspect?
2. How big of a dent did you make? This is the main aspect I'm stuck on before pulling the trigger
Greatly appreciate the info. It's be louder than ever and the driver side front door rattle has come back. Going crazy lol.
It was a fordtrucks.com forum post that gave the details. Not sure where that thread is now. It gave details to put the dents where I have shown. I dont know how to describe the size of the dents....pictures dont show it. Few very hard hits with a deadblow hammer and can use a socket extension as your denting tool. You should be able to feel a signficant depression with your hand but shouldnt look like major damage.
