Driver door rattle.
I have this same thing and it’s intermittent. Definitely not rivets.
The other day, if I pull the door towards me while it’s rattling, the noise stops, and immediately comes back when I let go. Seems to be maybe the striker…idk but it’s driving me insane!!!
Try wrapping electrical tape around it once or twice and see if it goes away. I had to do that.
You can adjust the striker easily without removing the bolts.
The electrical tape is an easy way to determine if it’s the striker though.
I tried this but dont see how it works. You can loosten the striker latch but the latch itself has sunken holes for the bolts. Once you tighten it back up, it self centers back to factory position.
That's not the way it works. The screws are countersunk yes, but the striker and nut plate trapped in the body clamps the entire assembly together, and the holes are oversized in the body, thus allowing movement of the entirely assembly. Mine is definitely not in the factory position, as all my wind noise has been eliminated now.
I see what you are saying now. I will try again. I pounded on the latch pretty hard to get it to move but didnt seem to want to budge.
No worries! I've found every one of these trucks has differing amounts of tolerance slop. What works for one, may not work for others. At least it's free to try 🍻
The first video in this thread is the exact sound I get. No one has seemed to find a solution, used magnet to check for rivets, pulled the door panel multiple times, no dice...wish somebody could figure this out
If not the door latch, possibly the door release cable or window drive cables? 🤷🏻‍♂️
Posted this a while back in another thread. Same exact noise as video posted at beginning of this one. Here’s the recording of my 2022.
2022 F250 door rattle
Dude…same exact noise!! Identical. You have never figured out where it’s coming from? Literally making me dislike driving my truck
Yeah when it’s there it drives me crazy. Music gets turned up. Fortunately for me it’s intermittent and there maybe 10% of the time. Neither me nor the dealership can pin down what’s causing it.
Gotcha. Bummer
