thx....interesting.Cool...open mind...open the link and read up Bro, lots of great info. The link is provided. ?? You can even call opti-lube and they will answer all of your questions.
Look up CP4 failures and you will find many good debates on this subject. I don't run with every tank of fuel, but its cheap and a peace of mind to help prevent a pump failure. They also have bypass kits to help protect your engine, some use both methods, others only do the bypass kit.thx....interesting.
Interesting thx.Look up CP4 failures and you will find many good debates on this subject. I don't run with every tank of fuel, but its cheap and a peace of mind to help prevent a pump failure. They also have bypass kits to help protect your engine, some use both methods, others only do the bypass kit.
Interesting thx.
stuff like this drives me insane. Reminds of of Harley's known ticking timebomb on their twin cam motors where they use a cam chain tensioner made of plastic. Metal rubbing on plastic for thousands of miles eventually results in catastrophic engine failure. Harley knows about it but won't just fix the issue so people go out and buy gear driven cam kits. Or lucky people catch the worn cam tensioner early and just replace it with another OEM plastic one.
I wasn't aware Ford has a similar philosophy to ignoring known issues. The clue is that these failures probably always happen well after warranty expiry......like for fuck's sake, just fix your known design weakness!
HOW IT WORKS
The CP4 pump is internally lubricated by diesel fuel from the tank. After lubricating the crankcase area of the CP4 pump, fuel enters the high pressure pumping chambers and exits under pressure to the fuel rails and fuel injectors. The weakness of the CP4 pump lies in the crankcase area where a set of roller lifters ride on a camshaft. When the failure event occurs the lubricating fuel becomes contaminated immediately. Our bypass kit mounts to the CP4 pump and changes the routing of the fuel flow so that lubricating fuel from the crankcase is directed back to the fuel tank to be filtered before going through the fuel system again. Thus all fuel entering the pumping elements of the CP4 pump and leaving for the injectors is always routed through both of the vehicle's fuel filters to eliminate any change of contamination from a high pressure pump failure.
www.spemotorsport.com
I know i sound like a broken record, look at all the other fuel additive posts that I have commented on. ITS ALL ABOUT THE FUEL! Ford and any other manufacturer base their additive opinions on the dream that all of the fuel we use is Top Tier. Its not. Other posts are correct that ULSD fuel lacks lubricity and its common knowledge. Also most manufacturers do have their own branded additives, if not needed they wouldn't offer it. Not reccomended means they are unable to research all the additive brands out there therefore they dont recommend any of them. Its a recommendation that we are talking about! They dont say "Do Not Use Additives" that would be what some are thinking, but they do say "We Don't Recommend" There is a big difference! Use of a good additive would make a big difference in fuel pump failures, Lubricant works. My 6.4l 2009 went 187k when I sold it, BG DFC+ in every fill up. Yes Every Fill up! BG DOC in every oil change ! It takes only a few miles to ruin an engine with a stuck injector, Cleaning and lubricating is the job of a good additive. Spend a few $ and save Thousands in repairs. I do Recommend AdditIves. IMHO.I'm a newly minted owner of a 6.7 diesel. Frankly, I'm a bit confused about fuel. #1 versus #2, "Synergy Diesel Efficient" from Exxon, etc. I live in Dallas where it rarely gets below freezing.
Does anyone have any recommendations regarding the best type of diesel fuel? Should I be using additives? Is so, how frequently?
Well said, lubricity is key!I know i sound like a broken record, look at all the other fuel additive posts that I have commented on. ITS ALL ABOUT THE FUEL! Ford and any other manufacturer base their additive opinions on the dream that all of the fuel we use is Top Tier. Its not. Other posts are correct that ULSD fuel lacks lubricity and its common knowledge. Also most manufacturers do have their own branded additives, if not needed they wouldn't offer it. Not reccomended means they are unable to research all the additive brands out there therefore they dont recommend any of them. Its a recommendation that we are talking about! They dont say "Do Not Use Additives" that would be what some are thinking, but they do say "We Don't Recommend" There is a big difference! Use of a good additive would make a big difference in fuel pump failures, Lubricant works. My 6.4l 2009 went 187k when I sold it, BG DFC+ in every fill up. Yes Every Fill up! BG DOC in every oil change ! It takes only a few miles to ruin an engine with a stuck injector, Cleaning and lubricating is the job of a good additive. Spend a few $ and save Thousands in repairs. I do Recommend AdditIves. IMHO.
Haha enjoyed reading your great post! A little prevention now can preclude out of warranty and out of pocket $$$$ issues later. ???? Go Air Force! ????I keep my trucks for a long time. Traded a 2005 PS for my Tremor. From my chair, OEMs have to find the sweet spot to balance risk and reward. They assume most folks are going to trade their vehicles at some average time of ownership as determined by the marketing folks. To be competitive and have bragging rights, they have to cut the cost to build and to own as low as possible. That's the vehicle they build. Stay within that window, averages are with you. There is always going to be a part built by humans that fail in that time. To keep owner maintenance cost as low as possible, they stretch out time between required maintenance as much as possible and still stay in the sweet spot. It would cost more to build a truck out of the factory that could keep the maintenance schedule and still go decades and hundreds of thousand miles for those of us that do that. Imagine if an OEM advertised you have to use a fuel or oil additive, etc. which as has been pointed out lightens your wallet. Probably not a good advertising scenario. So I choose to use third party additives and upgrades to avoid out of warranty issues a decade from now or at least minimize wear as much as possible because with the right care and feeding these trucks can go a very long time. I don't use Fram but the Fram oil man still said it best, pay me now or pay me later. If I was one that sold my truck every 3 -5 years or 36K/100K, which is where Ford has the sweet spot based on warranty, I would probably forgo the extras. My opinion which like a$$h@@ls everyone has one.
But I love this Forum!!!
Great article thanksThis is a good read on lubricity and additives by a certified diesel mechanic. Interesting that a smidge of bio-diesel can improve lubricity.
Archoil is good enough for a complete car crazy like Jay Leno........Thats what I am using!!There is a LOT of people running the Archoil ar6500. Maybe Archoil is the key to cp4.2 longevity?
I am looking to use Archoil, Opti Lube or Amsoil All in One...
Good lubricated clean fuel and frequent filter changes is probably key to longevity
This is an excellent article. I fully agree with the entire content of it. The HFRR tester may also be known as a bearing tester. Utube BG Moa testingThis is a good read on lubricity and additives by a certified diesel mechanic. Interesting that a smidge of bio-diesel can improve lubricity.
This is a great article based on facts not hearsay. ITS ALL ABOUT THE FUEL!This is a good read on lubricity and additives by a certified diesel mechanic. Interesting that a smidge of bio-diesel can improve lubricity.
Like most Celebrities with mucho money, It doesnt mean they are any smarter or authorities on anything. IMHO.Would Jay Leno lie to you?
