www.racornews.com
So you're saying stay away from biodiesel because of the potential for water contamination?I think it would take some ma and pop gas station way off in the boonies to make me even moderately concerned about getting 'old' fuel. Besides, I'm getting an S&B 60 gallon tank so I won't be forced into stopping at sketchy joints. That said fungi and microbial contamination is real and it is largely due, or greatly enhanced, by water in tanks. This is a serious concern with jet fuel at podunk or third world airports. I've noted before that an Antonov 124 (B747 sized) crashed in Russia in 1997 due to water contaminated fuel killing 23 crew and 49 on the ground.
water in diesel:
Water, A Diesel Engine's Worst Enemy
Part 2: Revisiting the Racor Filtration Guides Water is commonly found in diesel fuel due to condensation, handling and environmental conditions. Diesel fuel tanks are always subject to water condensation because diesel fuel, unlike gasoline, has no vapor pressure to displace air. When a...www.racornews.com
From above article:
"Good to know: Using biodiesel at 5% makes removing water more difficult. At 20%+ biodiesel concentration, water removal can be much more difficult to near impossible."
I use Archoil, seems to be doing great. My first diesel.Archoil AR6500 has many loyal fans, including Jay Leno! LOL
Your manual says something to the effect that Ford does not recommend additives BUT if you use them they should be Motorcraft. Double LOL
I have a 2,000 gallon diesel tank and was told by the company that fills it up that all diesel is made the same way other than sometimes they do put additives in the diesel but that cost more , idk wheather that’s true or how much to believe anything anyone says anymore honestly.I don't know much either but was told that the "Synergy" from Exxon does not contain any recycled components like other diesels can. I try to use Exxon Synergy exclusively if I can. Also they have an APP that allows you to pull up to a pump and activate the pump and pay with your phone, no need to put your credit card in at all. Just pull up, activate, and pump. Also collects points for $$ off your future fill ups.
I have been using Archoil since day 1 in my fuel....the fuel system in the 6.7 cost 8k....and if it fails...is likely to take out your motor.....the additive helps prevent bad fuel from ruining your fuel system.....and that is why i use it.I use Archoil, seems to be doing great. My first diesel.
I’m a firm believer in BG44k in all my️‘ers.
Im with you, BG 44k is an excellent product. BgG also has great Diesel Products. I use BG DFC in every fill up on my Tremor. And also used it for 190k on my 09 6.4l. A 1 gallon container takes me over 30k miles I use about 1 ro 2 on per fill up. I also use theit DOC product in every oil change, it reduces carbon and ash and improves TBN numbers for overall oil performance. IMHO BG does some of the best r&d in the business.I use Archoil, seems to be doing great. My first diesel.
Not exactly---in the refining process to take the Sulfur out that is where the lubricity was removed. Sulfur does not provide any lubrication. Common mistake made when reading about this on the internet.So the problems started when diesel was refined to a "low sulfur" specification. Sulfur provided the necessary lubrication beyond what the diesel fuel itself could provide. Now the diesel is so "dry" that it no longer provides the necessary lubrication for the cp4 to have a long life. It will last beyond the warranty... but will be losing efficiency along the way. The oil we use has the same problem. Some years ago now, zinc was removed (mostly) from oil for emissions reasons. Guess what flat tappet camshafts require to be happy over time? Zinc... (check out Gibbs break in oil for race engines and see what it has a lot of)
So some tests were done using ASTM standards for wear were done and Opti-lube and straight bio-diesel showed most improvement. Power Service silver bottle was high as well (used diesel oil also showed improvement). Now other things like transmission fluid and Marvel Mystery oil showed worse wear.
The science and tests are out there if you want to look for them ... or not. Up to you. Like the Fram guy said, pay me now or pay me later.
I doubt anybody here, if anywhere, is qualified to pass judgement on which additive is best. I presume all are comparable. I'm sure
the Motorcraft is good but I'm philosophically opposed to letting
the fox guard the henhouse.
You guys and your 7.3’s! Could you please quit trying to justify your purchase and just enjoy your rig and your trips to the pump!Exactly & that’s just another reason I went 7.3L, no need to dump expensive additives in the tank & hope they do something that makes me feel good![]()
