I’ll stick with Schaeffer’s. Have been using it since first oil change. Truck seems to really like it.I used to be a road warrior, but now I'm fortunate to not log nearly as many miles as I used to.
So in short sounds like the triax does pretty goodHere’s my most recent:
First two are FoMoCo oils, most recent Triax. Air filter was two years in needing a cleaning (higher silicon reading) also keep in mind I’m a terrible diesel owner my drive currently it’s 10mi roughly to work. I paid a little extra for soot and TBN results. Def think a good bypass filter would help if we’re planning to do long OCI.
Soot levels become important at higher OCI as they’re abrasive and can clog ports.
Celsius here in Northern BC but theAnd here I was about to order a drum of Amsoil after I move; not recommended
i run 5-40 year round also, it gets to -40Rotella 5w40 ALL YEAR LONG is ALL you need -54*F pour point. ... As an Amsoil dealer, I use Rotella 5W40.![]()
Yes, I used it religiously in my 6.0 but I wouldn't run anything 10k+ without a bypass from what I'm seeing. I'll probably keep mine limited to 7500 or Built in oil monitor. Mine was at 0% when I did this changeSo in short sounds like the triax does pretty good
Damn it showed 0% at 7900 miles. I’ve been using rotella t6 for years since amsoil started getting stupid with prices, now I’m skeptical and may switch to triaxYes, I used it religiously in my 6.0 but I wouldn't run anything 10k+ without a bypass from what I'm seeing. I'll probably keep mine limited to 7500 or Built in oil monitor. Mine was at 0% when I did this change
I do a lot of short drives and always traffic sucks, I'm sure that's why the IOLM triggered so earlyDamn it showed 0% at 7900 miles. I’ve been using rotella t6 for years since amsoil started getting stupid with prices, now I’m skeptical and may switch to triax
We all started somewhere. Triax held up very well to hpop abuse."Old" 6.0L guys and oil change habits....![]()
I always love the "truck seems to really like it quotes"! Asked mine many times if it liked the oil---never get a response.I’ll stick with Schaeffer’s. Have been using it since first oil change. Truck seems to really like it.
True, but the little bit more pricey oils tend to have a better detergent package and moly content than oem oils granted if you’re changing more frequently then it probably doesn’t matter, just as an example if you ran motorcraft 7500 miles or less or able to run say triax or whatever brand 10k miles I’d rather do 10k intervals. Don’t get me wrong I wouldn’t waste the money on the cost of schaffers, amsoil or hotshots secret or alike just seems way to over priced in my eyesReading this and other threads i always come to exact same conclusion that recommended OEM motorcraft oils are as good as any other oils and changing oil more frequently is far more important than wasting money on hyped up and over marketed aftermarket oils that supposedly “do better” because my truck “seems to really like it” notions.
Just depends on how you use the truck. NOAK ratings are huge for me and not all of the oils mentioned here on this thread do that well. http://www.pqiamerica.com/Testdescriptions/Noack.htmlTrue, but the little bit more pricey oils tend to have a better detergent package and moly content than oem oils granted if you’re changing more frequently then it probably doesn’t matter, just as an example if you ran motorcraft 7500 miles or less or able to run say triax or whatever brand 10k miles I’d rather do 10k intervals. Don’t get me wrong I wouldn’t waste the money on the cost of schaffers, amsoil or hotshots secret or alike just seems way to over priced in my eyes
I guess your not much for a feeling are ya! Maybe she doesn’t like your tone!I always love the "truck seems to really like it quotes"! Asked mine many times if it liked the oil---never get a response.
You do you! I’m sure you have and will continue to “waste” money on ever more stupider shit! Just take inventory on yourself. I’m sure you will find plenty!Reading this and other threads i always come to exact same conclusion that recommended OEM motorcraft oils are as good as any other oils and changing oil more frequently is far more important than wasting money on hyped up and over marketed aftermarket oils that supposedly “do better” because my truck “seems to really like it” notions.
I put in Super Tech (Walmart) conventional 15w40.
