Glad to hear they went to that extent and didnt just tell you "its working"The shop who replaced my hubs last month popped the diff cover, tested and inspected the locker, functioning as inteded and replaced the gear oil. There was a tiny dab of water in the oil but nothing to be alarmed about (as I was told); my diff breather tube had ripped off (lord only knows when).
All this was addressed and corrected as necessary.
I would certainly get the vehicle off the ground and start rotating by hand as @FuelTankReInforcedSkidPlt mentioned. I was going to suggest maybe pulling the front shaft. But, if you get it off the ground and can reproduce by hand spinning, i think youll source it pretty quick.
Can you run it without the hub(s) installed? (this is my first solid front axle vehicle so.. if thats dumb to suggest note that I never claimed intelligence to start)
I'm a huge fan of 1000% eliminating things from being potential source and an even bigger fan of not assuming stuff works.
Best of luck Az
