I built it for travel towing. I've had a 21' Bigfoot trailer for traveling and stayed small and light just so I could get in anywhere boondocking. I always go loaded with something in the bed even after I unhook and setup camp and wanted the articulation on back roads and trails. My last truck was mainly for baja and coastal access for surf. The softer progressives in the rear put the full travel airbags with pucks in contact with 500# in the bed, and the truck bed really WAS level. I wanted freer travel offroad, did the math and the next morning CJC was kind enough to swap out the softer for the HD's and everything came out perfect. I've been in some rough riding trucks, and 37's under the Pintop w/ HD's is not it. I have about a year on it and couldn't be happier with my setup for how I use it. Following threads in this last year, look for TellurideTremor, because I think he was going to do some suspension work and was going for the HD's for similar reasons.
On a regular day, I run empty with a smartcap shell (which is next to nothin'). The ride for me is firm and smooth unless I'm running through a bad patch of expansion joints in the fast lane of an old freeway, in which case I just move to a middle lane which runs smoother.
No trophy Hitch because I didn't want to go 3". If they made a 2.5", I'd probably get one, and depending on who is making what, might bump the tires up to 38's.
I'm retiring in the next year or so and beenlooking at 28' airsteams which will have the heavier hitch weight. That factored in to my thnking. Same gear in the bed. I also didn't want the weight lower capacity of the softer rear leafs.
Hope that helps. If I ever get aound to it, I'll start a build thread, hopefully before I look do the lights and possible air. As far as the suspension, I wouldn't change a thing.
