Carli guys - what rear leafs are you running?
Carli full progressive leaf pack with their shims and shackles, honestly this is your biggest bang for the buck.
I'm using the stock rear leaves combined with Sulastic Hangers, King Pintops, Airlift Ultimate Bags and a HD Helwig Sway Bar.
For reference, I have the full pintop kit with everything including the torsion sway bar.View attachment 234921
may end up there someday but i've got a handful of toys so i'm trying to be lightly responsible with the super duty. as soon as the lift is on i'll take it to my shooting spot and if i get the shit kicked out of me on the way out there i know i'll need to address the rear end
My truck is paid off so it’s easier to do stuff like this. I really like blasting down dirt roads, fire roads, ruff Forrest roads, etc. When you ride in a truck with a full carli suspension nothing compares.
Like like a little rake - but I also like 37’s so I did
2.5” ready lift
Fox performance elite 2.5 dual reservoir for front and back
Carli torsion sway bar
Carli upper/lower steering stabilizer
Carli progressive leaf springs
Full travel bags
Around 1” rake where as the Carli springs would sit me level.
XHD leaf pack and Full Travel Airbags filled with an arb dual brushless/Pacbrake controller.
Can I install Carli’s rear shackles on the stock leaf springs and what benefits can I expect?
i believe you can and dudes on here have said it made a noticable difference. Not bad for a couple hundred bucks.
running Carli HD progressives including the shackles with full travel airbags. Kings all around. I had, and took off standard progressives. It probably firmed up the unloaded ride a little, but nothing that bothered me, and it gave me back a little rake so I could use the truck without it being a squatter. My woman doesn't snivel about the HD's in the rear either, and if it did I'd be getting squeaking out the passenger seat. Nobody wants that. The full travel bags are for heavier towing which hasn't happened yet, but it frees up the rear axle travel.
Curious how this compares to the stock Tremor rear springs? This is the setup I'll move to eventually as I'll want capacity for a slide in truck camper that'll weigh around 1500-1700 lbs.
I have the shackles on mine and there was a noticeable improvement in small bump compliance.
Yes you can and that's how my rear setup is.
On road, zero noticeable difference.
Offroad you'll see and feel the rear articulate much easier.
I could give you the long story, but the short version is if I wasn't runnin' trails aggressively, stock leafs would be very passable. I originally ordered the full pintop kit w/ the HD in the rear, and at the last minute, went with the regular progressives on advice, and instantly regretted it. Mainly because of the sag in the rear with a 500# load in the bed. I could have had the stock rear leafs put back in, but I went with the HD's instead because of the intended use of the truck. I also ran progressive springs in my last truck, and I'm convinced the benefit is real and worth the investment, so I was inclined to go that way anyway. I picked up an inch and a half or so of rake w/ the HD over the stock leaf height, so for me the profile of the truck looks normal as opposed to level with the pintop kit. Empty, it might be just a shade more firm. As far as how it handles with your foot into it, it tracks like it has serious intentions which ever way you point it. Which ever way you go, the tires you put under it are going to affect it more that you know.
If you're putting any kind of load in the bed or on the hitch, I'd pass on the standard progressive leafs. I don't see a problem if someone ran stock leafs to see if it was satisfactory, but I'm extremely happy with the HD's over stock leafs, and highly recommend it unless what you're truly after is a 'leveled' truck. That might not be a popular opinion with the off-road crowd, but it fits for how I use the truck around town
This is worth watching. I put my hands on this truck before I ordered anything. He's on 38's, I'm on 37's
Thanks for the input. I've run some pretty serious trails with my stock Tremor and was pretty impressed with it with just the front sway bar removed and 36" MT's. I prefer the rakes looked as a leveled truck never looks leveled and seems to defeat the whole purpose of the truck. I want to haul things, etc and not worry about it looking like a Ford Ranger. It sounds like the HD progressive springs ride better than stock Tremors while still providing load capacity which is what I ultimately want.
I just went down this rabbit hole. I quickly dismissed the standard springs because I need to haul/tow and almost never ride empty.
The HD springs made the most sense but when I have 1000lbs in the bed and tow my dump trailer it may sag more than I want and I considered airbags with the HD springs.
My plan is a truck camper @1800lbs and after watching the CJC video about a four wheel hawk and they tried the XD springs and bags and he didn’t like it and switched to the XHD springs.
So far with the XHD springs and my usual 800lbs in the back it’s a little bouncy on certain roads until you go a little faster and it rewards with a little more aggression. They have more articulation/travel than the stock springs by quite a bit which is a significant improvement off-road.
If I wasn’t going for the slide in i would definitely get the HD springs for all around.
When you go up on the spring capacity they increase the shock valving accordingly and makes the package more capable but less comfortable.
More tools and more sandbags for the time being!
Great input as well. The easy solution is adding bags, however that's not ideal if I ever truly offroad (even a bit) with a slide in camper which will very likely happen. I fear the bags would either limit travel, or be damaged due to extreme travel. A buddy of mine has the Carli Backcountry kit and left his rear springs stock on his '23 F350 Xcab shortbed, although it's not a Tremor, he also wheels with a 4WC in the bed, it does squat a little but doesn't look awful surprisingly.
