Camper Shell Options for Super Duty Tremor
Got my ARE Z topper installed this morning. Extremely happy with fit, finish and install. I used upgraded rubber bulb seals. Paint match is perfect, no paint rubbing, great clearance with rubber bulb seals. Happy Camper.
View attachment 8457View attachment 8454
how long a wait was it ?
Sure anytime. Just a suggestion - consider the upgraded bulb seal. I am glad I went with it. Much better than the cheap foam seal which flattens out over a short period of time. Have the installer stick it on the shell not your truck bedrail. If they stick it to the bed rail it will leave glue residue on the bed rail that is a PIA to remove if you ever decide to remove the topper. Just a thought. Worth every cent!
Thanks
I will
I did ask them about it when I went to order it and they brushed me off. I will order it and bring it when I go have it installed. Thanks for your opinion and help, I am as picky as ever but I really do not know the difference without you pointing it out, never had a cap. I do plan on removing when needed
thanks again !!!
I forgot to mention, I also bought this rubber seal to the leading edge of the bed. It worked perfectly. Stay away from the foam tape that installers use, it’s cheap and flattens out quickly. FWIW..
Sounds good
Anyone install a taller then cab cap yet? Like are mx or leer 180?
I have not seen one on here yet. I considered it but quickly realized due to the taller height of the Tremor it would not fit in my garage and that was a show stopper.
